Rich&Mar
wa usa
I'm thru taking the fiver out for the winter. Probably won't go out again for 5 months at least. Do you raise your rv so the weight is off the tires? I never have in the past, but at the price of tires today, I'm thinking I'll start. And do you put a pair of jack stands under each axle? I've read that this might ever so slightly bend the axle when left for months. So where would you put the stand not to do damage?
rich
md_procouple
Parkville, Md.
No have never done that, but I do move the Fiver a few feet every month or so. Good Luck and Happy Camping !!
Vickie, Me, and "Scruffy" our dog make THREE
DutchmenSport
Indiana
It doesn't matter what kind of vehicle it is, if you want the tires off the ground, use jacks stands under the frame. To life completely, at minimum of 4 jacks, one on each corner of the frame. More is better, mid way for 6 and in sections of 1/3rd for 8.
You do not want to lift the camper by the axles. You will run the risk of bending them. Lift at the frame near the axles one side at a time, and rest the frame on several points of contact. Then do the other side the same way.
pcm1959
home
Our fiver is parked at our home on a packed gravel driveway. We take it out once a month and it has a Big Foot leveling system. I have always kept it leveled with the weight off the suspension (tires not necessarily off the ground) since owning it nearly 6 years. I feel its better for the springs and tires. So for the extended period you are looking at, I say "yes".
2018 GMC Sierra 3500 DRW 4x4 Duramax/Allison
2014 Lifestyle LS36FW
St Augustine, FL
cougar28
Lowell,AR USA
Never have and don’t really see any need to.
2002 F-250 SD CC 7.3PSD Auto. XLT Short Bed 4X4 Off-Rd.Pkg.Highland Green,Westin Sportsman Grille Guard (Black) RBW Li'l Rocker Slider ,Prodigy Control Towing Jayco Eagle HT 30.5 MLOK,Handy 5er tailgate
laknox
Arizona
cougar28 wrote: Never have and don’t really see any need to.
What ^^he^^ said. FWIW, though, when I do jack my trailer, I jack right under the spring perch. Were I to store my rig off the wheels completely, I'd jack it up, remove the wheels and store them inside, then lower it down onto jack stands on the frame. I'd also keep some weight on my 4-pt leveling system as well as the frame jacks...just 'cause.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 61 Year Member
Cummins12V98
on the road
Buy QUALITY tires. I never cover or lift. I am in the Sun all the time.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
fj12ryder
Platte City, MO
Nope.
Howard and Peggy
"Don't Panic"
azdryheat
Tucson, AZ
Goodyear says to increase tire pressure 25% for long term storage.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
ScottG
Bothell Wa.
I used to do stuff like that but stopped a few years ago. Nothing bad has happened so far!
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
