RV.Net Open Roads Forum: Fifth-Wheels: do you do this
 > do you do this
MFL
Midwest
Posted: 11/15/19 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
azdryheat wrote:
Goodyear says to increase tire pressure 25% for long term storage.
I use this idea, but I only increase 10 percent. I know that cold weather, will decrease the pressure, as warm does increase. Towing at speed raises pressure a lot. IMO, I think maintaining a stiffer sidewall helps for long term storage.
Me, I'd not get carried away lifting/supporting. I'd buy better tires, or replace more often, if I was concerned.
Jerry
BB_TX
McKinney, Texas
Posted: 11/15/19 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
Never have. Last set of tires replaced after 8 years due to age. Parked on crushed rock in covered storage and typically never moved from late Oct til April. And they still looked nearly new with about 22,000 miles on them.
Super_Dave
Harrisville, UT
Posted: 11/15/19 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
I store with all 6 jacks down. How much weight is really on the tires?
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
Splashers3
Oakville, MD
Posted: 11/16/19 03:53am Link  |  Quote  |  Print  |  Notify Moderator
I never have lifted tires, however, I do inflate a few pounds over their limit. I like the idea of moving the trailer a bit. I also re-inflate as winter wears on and tire pressure drops.
2017 GMC 3500 Sierra Denali, C/C, D/A, DRW, w/40gal Aux tank, 18K B&W Patriot.
2019 Cedar Creek Hathaway, 34RL2 - w/Bells & Whistles and disc brakes
Traded 2009 Cedar Creek Silverback, GII, 32 WRL
frizfreleng
Aleutians West
Posted: 11/16/19 07:46am Link  |  Quote  |  Print  |  Notify Moderator
I will guess you are concerned about flat spots on your tires. My understanding is that it is not an issue with radial tires but was for bias ply.
4x4ord
Alberta
I think supporting the trailer by the frame over winter is a good idea even though I've never bothered with it. I blow the water lines out, disconnect the batteries and don't look at it again from September 1 till about the middle of June.
2017 F350 SRW Platinum short box 4x4.
B&W Companion
FlatBroke
CO/AZ
Posted: 11/16/19 08:06am Link  |  Quote  |  Print  |  Notify Moderator
Another nope from me
Hitch Hiker
"08" 29.5 FKTG LS
Veebyes
Posted: 11/16/19 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
The first couple years I lifted it & supported it by the frame. Don't know why. Lots of vehicles spend lots of time in storage & always on their wheels. No harm. I make sure that tires are at proper pressure. That is it.
2007 Alpenlite 34RLR
Pipeman
Windsor, Ontario,
Posted: 11/17/19 05:01am Link  |  Quote  |  Print  |  Notify Moderator
I have never lifted any of my TTs or 5ers tires off the ground when in storage from Oct. to May. My brother in law lifts his 5er and then takes the tires off for the winter. To each his own.
Pipeman
Ontario, Canada
35 year Fire Fighter(retired)
VE3PJF
Dave H M
IL
Posted: 11/17/19 06:53am Link  |  Quote  |  Print  |  Notify Moderator
Would not even think of doing al that horsing around. [emoticon]
 > do you do this
