RV.Net Open Roads Forum: Fifth-Wheels: do you do this
 > do you do this
RAS43
Littleton,CO
Posted: 11/17/19 08:25am Link  |  Quote  |  Print  |  Notify Moderator
Dave H M wrote:
Would not even think of doing al that horsing around. [emoticon]
X2 In 40+ years of RVing I have had 1 tire failure. Air up and cover tires and park on gravel or old mud flaps is all I do.
cummins2014
Utah
Posted: 11/18/19 10:13am Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
Buy QUALITY tires. I never cover or lift. I am in the Sun all the time.
That would mean Sailun S637's , correct ??? [emoticon] . That would be the best bang for the buck !!!
cummins2014
Utah
Posted: 11/18/19 10:16am Link  |  Quote  |  Print  |  Notify Moderator
Pipeman wrote:
I have never lifted any of my TTs or 5ers tires off the ground when in storage from Oct. to May. My brother in law lifts his 5er and then takes the tires off for the winter. To each his own.
I would thing just covering them would accomplish the same thing. You need to have a talk with him [emoticon]
cummins2014
Utah
Posted: 11/18/19 10:18am Link  |  Quote  |  Print  |  Notify Moderator
Same here in over 50 years , just one tire failure ,and that was plenty
allen8106
Burrton. KS
Posted: 11/18/19 11:54am Link  |  Quote  |  Print  |  Notify Moderator
Rich&Mar wrote:
I'm thru taking the fiver out for the winter. Probably won't go out again for 5 months at least. Do you raise your rv so the weight is off the tires? I never have in the past, but at the price of tires today, I'm thinking I'll start. And do you put a pair of jack stands under each axle? I've read that this might ever so slightly bend the axle when left for months. So where would you put the stand not to do damage?
No I don't and it's never caused any issues I'm aware of.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 36
bpounds
Sophmore Brain...
Posted: 11/18/19 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
You're going to be replacing them due to age anyway. And lifting isn't going to make them age any less.
Keep them covered from sunlight if you want maximum life of the rubber.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
C Schomer
Pueblo West, Co.
Posted: 11/19/19 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
I have two large pneumatic cylinders and I can raise my fiver up and put it on jackstands in under five minutes. I tried keeping it off the ground during storage for several years and that didn't make the ST go pop tires last a bit longer. I even had one of those go pop tires blowout over the winter while it was off the ground and covered. After two sets of go pops in a row only lasted four years, almost to the month of manufacture, I switched to ST tires.
I'm going to store my fiver off the ground again because I can do it so easy. I've also read that the air pressure can be let down when the tires are stored with no load on them. Craig
TazFord
Colorado
Posted: 11/21/19 09:20am Link  |  Quote  |  Print  |  Notify Moderator
To help prevent dry rot don’t park directly on soil, asphalt, or concrete. Park on leveling pads or similar
Life long camper, First time Fiver
2018 Starcraft Solstice 29BHS—2008 Chevy Silverado 2500HD
laknox
Arizona
Posted: 11/21/19 09:42am Link  |  Quote  |  Print  |  Notify Moderator
I bought some 2x6 redwood, cut them in half and run my rig up on those. I feel that it bought me time, especially with the first couple sets of China bombs. Always covered, too.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
fj12ryder
Platte City, MO
Posted: 11/21/19 10:15am Link  |  Quote  |  Print  |  Notify Moderator
I park it on concrete, cover the tires, and that's it. So far they've lasted 6 years and still look good. Not fond of making work for myself.
Howard and Peggy
"Don't Panic"
 > do you do this
