RV.Net Open Roads Forum: Tech Issues: So Valvoline has this meeting...
 > So Valvoline has this meeting...
Gdetrailer
PA
Posted: 11/15/19 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
STBRetired wrote:
Yeah, so how do you ell when it's time for new grease?
That's easy..
When the bearings seize!
[emoticon]
[emoticon]
midnightsadie
ohio
Posted: 11/16/19 05:33am Link  |  Quote  |  Print  |  Notify Moderator
LOL how true.
72cougarxr7
Northern NY
Posted: 11/16/19 11:46am Link  |  Quote  |  Print  |  Notify Moderator
Bearings dont "make black stuff".
And the color of the grease is really not an indicator of its condition.
Gdetrailer
PA
Posted: 11/16/19 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Bearings, no, they won't turn the grease black or any other color.
HOWEVER, DIRT/DUST/BRAKE DUST/WATER can and does change the color of the grease.. Poor or worn out dust seals can allow all of the above to creep in to the bearings and grease.
Improperly set bearings can also cause overheating of the grease and can turn any grease black in a hurry.
Always best to check and repack your bearings periodically, fresh clean grease is always good and well worth the effort.
352
Oxfofd, Fl
Posted: 11/16/19 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
I googled that and you are %100 correct. So it must be true
The manatees of Halls river Homosassa Springs Fl
1985 Chevy Silverado c10. 454 stroker / 495 CI = 675 HP. 650lb of torque. Turb0 400 tranny. 3000 stall converter. Aluminum heads. 3 inch exhaust flowmasters. 2 inch headers. Heat and air. Tubed.
Gdetrailer
PA
Posted: 11/16/19 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
I do know that the OPs post was a joke, not so much for yours.. But thanks for the potential sarcasm.
Lynnmor
Red Lion
Posted: 11/16/19 11:19pm Link  |  Quote  |  Print  |  Notify Moderator
I had a cheap Chinese bearing that had a ridge on the inner race from improper manufacturing and it turned the fresh red grease to gray in short order. No contamination from external sources, just the fine metal particles from the junk bearings.
