RV.Net Open Roads Forum: What is the purpose of low point drains?
 > What is the purpose of low point drains?
JoshuaH
Jefferson City, Mo
Posted: 11/18/19 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
New camper we bought has low point drains under the camper for both the hot and cold lines.
I assume this is for draining the water system, is this a good enough method for winterizing? Is it just for winterizing if you are caught off guard and don't have any antifreeze?
Just wondering exactly what the purpose of these are.
Thanks!
allen8106
Burrton. KS
Posted: 11/18/19 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
They are for draining the water out of the system at that low point. You'll still need to close them after draining and either blow the lines out with air or winterize with RV anti-freeze. I prefer the anti-freeze method. Your choice though depending on how much risk you're willing to take.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 36
Lynnmor
Red Lion
Posted: 11/18/19 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
If all the plumbing was sloped towards the low point with absolutely no sags, then maybe it would work. But RV's are built any which way and you can't count on draining properly.
JoshuaH
Jefferson City, Mo
Posted: 11/18/19 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
That is what I was thinking, so I was wondering what is the point of having them there in the first place.
schlep1967
Harrisburg, PA
Posted: 11/18/19 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
If you open all spigots/taps before opening the low point drains, you should get most of the water out as it will act like a siphon. Once that is done close the low points and spigots/taps. Add antifreeze to the lines running it through every line and tap.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
Old-Biscuit
Verde Valley
Posted: 11/18/19 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
Because W/O the Low Point Drains HOW would you get the water out of the Hot/Cold water lines???
Open the Low point Drains.....then with an adapter connected to City water inlet you can BLOW air thru the Lines and remove majority of water in the system
Course there is the issue of the water pump.
RV Anti-freeze pumped thru the Cold & Hot Systems (out faucets/showers/toilet AND Low Point drains you get rid of the water and protect with anti-freeze
W/O Low Point Drains that would be hard to accomplish.
Course...one doesn't have to use them
dodge guy
Bartlett IL
Posted: 11/18/19 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
When I had my trailer I didn’t even drain the lines. I ran antifreeze through the system until it all came out pink. Never had an issue. If I’m not feeling lazy then I’ll pull the low points and drain, otherwise I just run the pink through it.
* This post was edited 11/18/19 05:41pm by dodge guy *
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Yosemite Sam1
Under the pines.
Posted: 11/18/19 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
Otherwise you'll be carrying a dead load of water every time, duh![emoticon][emoticon][emoticon]
schlep1967
Harrisburg, PA
Posted: 11/18/19 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
dodge guy wrote:
When I had my trailer I didn’t even drain the lines. I ran water through the system until it all came out pink. Never had an issue. If I’m not feeling lazy then I’ll pull the low points and drain, otherwise I just run the pink through it.
If your low point drains are valves above the floor line you can get away with this. If they are caps below the trailer, do yourself a favor and drain them. If you don't there is a good chance you will have nothing but water in the lines hanging down. No antifreeze. When those caps freeze and crack you will have a problem next year.
Yosemite Sam1
Under the pines.
Posted: 11/18/19 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
Seriously this time, I would suggest you run the pump while all faucets are turned on or open to drain all water in the lines. Then open the low point drains.
Do these again after you've loaded the 4 to 6 gallons of RVC fresh water anti-freeze.
Others suggested blowing air to purge all water inside. I just installed a water accumulator and indeed there are bent pipes where water can accumulate, freeze and crack.
