RV.Net Open Roads Forum: Class A Motorhomes: Why no continuous furnace fan option?
 > Why no continuous furnace fan option?
time2roll
Posted: 11/20/19 10:38am Link  |  Quote  |  Print  |  Notify Moderator
The furnace runs and cycles independently on its own controls. Thermostat just says go or stop.
This is different than the A/C unit that can be controlled with thermostat selections. At home the central AC and Heater are the same unit so again they can be controlled by the thermostat selection for fan.
675w Solar pictures back up
dougrainer
Carrolton, Texas
Posted: 11/20/19 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
I have only seen one of these and they are usually in hi line 5th wheels. Doug
https://www.camperpartsworld.com/RV-Atwo........urnace-Excalibur-xt-25000-40000-BTU.html
Williebago
Wichita, KS, USA
Posted: 11/20/19 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
I have three remote thermometers at key locations in the basement around water piping and in the wet bay. When driving down the road in my gas coach, the basement thermometers indicate temps about 10 degrees above the outdoor ambient. So when driving below 20 degrees outside, it would be nice to have the furnace fan pump cabin air into the basement to protect things.
I recognize the furnace fan is a real drain on the batteries, but that would not be a problem if parked and plugged in or while driving with the engine alternator doing the charging.
On a side note, the furnace manual says do not run the furnace while driving.
WILLIEBAGO
2019 Newmar Baystar 3626, F53, 252"WB with 6.8L gas engine
2003 Jeep Liberty Limited Toad
2 cockapoos, Jordy and Nelson, who love RVing
Go K-State Wildcats
doxiemom11
Yoakum Texas
Posted: 11/20/19 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
We have been in some pretty cold temps where it did not go above freezing in the day and for several days in a row. With the furnace set at 60 at night and 68 during the day, no problem with the tanks. I don't think they need continuous heat to keep from freezing unless you are in the minus temps, then maybe.
dodge guy
Bartlett IL
Posted: 11/20/19 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure about anyone else, but I don't want to hear the furnace fan running 24/7!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Heisenberg
West Texas
Posted: 11/21/19 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
Mine heats everything back to the waterheater from the engine coolant via a switch on the dash. While travelling.
2013 Winnebago Sightseer
2017 Colorado
sundancer268
Charlevoix
Posted: 11/30/19 05:31am Link  |  Quote  |  Print  |  Notify Moderator
I run my Suburban Furnace going down the road anytime I am cold. The dash system will not supply enough heat to keep us warm. Though I have found out that if the furnace flame goes out, the fan will keep running blowing cold air, so maybe you could just shut off the propane and start the furnace, the flame will not light and the furnace will go into the fault mode and the fan should keep running. At that point you can turn your propane back on and the furnace will not start up though the fan will still be running. When you get to where you need the furnace and the propane is on, just shut off the furnace at the thermostat for a minute or so until the fan quits running and then turn the furnace back on. I found this out when we woke up freezing one morning where the furnace had gone out during the night and the fan had not shut off, it was just blowing cold air. I pulled the furnace fuse and then restored power and the furnace took right off and started supplying heat. I later discovered all I had to do was shut it off at the thermostat and it would restart when the thermostat was turned back on.
U. S. Navy (RETIRED) 1993
1995 Gulf Stream Scenic Cruiser 34' Diesel Pusher Cummins B5.9 12 Valve Engine, Allison MD-3060 6 Speed Transmission.
TOAD: 2019 Jeep Cherokee Trailhawk Elite
Road Master Sterling All-Terrain, Airforce One
hohenwald48
Nashville, TN
Posted: 12/05/19 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
I installed a switch that allows me to turn on the furnace fan constantly if I want. It involved some splicing and wiring inside the furnace unit. I only use it to keep the basement above freezing when necessary. It's a pretty simple mod if you can read an electrical schematic.
When seconds count, the police are only minutes away.
2015 Open Range 216 RBS
2013 Nissan Armada Platinum
