RV.Net Open Roads Forum: Class A Motorhomes: Why no continuous furnace fan option?
 > Why no continuous furnace fan option?
Williebago
Wichita, KS, USA
Posted: 11/19/19 10:13pm Link  |  Quote  |  Print  |  Notify Moderator
I am on my second 35 foot gasoline powered Class A coach and both have two roof mounted Dometic heat pumps and a separate gas furnace, one an Atwood and the other a Suburban. The heat pumps have high/low/auto fan positions, but the furnace only has an auto position. Why is this?
My stick and brick house furnace has a continuous fan setting. It would be nice when it was really cold to have this option so the furnace could supply some warm air to protect the water tanks and piping in the basement, whether driving or parked and plugged in.
WILLIEBAGO
2019 Newmar Baystar 3626, F53, 252"WB with 6.8L gas engine
2003 Jeep Liberty Limited Toad
2 cockapoos, Jordy and Nelson, who love RVing
Go K-State Wildcats
rk911
Wheaton IL
Posted: 11/19/19 11:06pm Link  |  Quote  |  Print  |  Notify Moderator
we leave the fan on 24/7 at our home, too. don’t know but my guess is that our homes hold the heat better and longer than in our RVs. they cool down a lot faster and a running fan would just blow cold air.
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
Wherever I happen to park
Posted: 11/20/19 05:07am Link  |  Quote  |  Print  |  Notify Moderator
THe fan burns 12 volt battery power. not 120 volt Mains power (though the converter does convert it) .. Frankly I do not know why no full time fan.
I do turn one AC on fan only for air circulation from time to time.
Home is where I park it.
Argosy24
MI
Posted: 11/20/19 05:39am Link  |  Quote  |  Print  |  Notify Moderator
A combination of the relatively small mass of the motor home cooling quickly, batteries dying even quicker, and a motor that isn't rated for continuous duty?
rockylarson
Jersey Shore
Posted: 11/20/19 06:05am Link  |  Quote  |  Print  |  Notify Moderator
The air flow from the fan moves the sail switch that tells the furnace that it is ok to release propane and start the igniter.
Not an expert but that is my simple understanding. Somehow I don't think having that safety feature open or not functioning is not advisable.
Jan and Rocky
Volunteers for USFWS. 25 refuges with 8000 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
dougrainer
Carrolton, Texas
Posted: 11/20/19 06:20am Link  |  Quote  |  Print  |  Notify Moderator
RV furnaces are designed to operate with a specific RPM. That is so the safety controls will function as designed. IF you had a continuous fan mode, that means the safety controls would have to be bypassed. COST is a factor. Home systems cost a lot more and the control systems cost a lot more. When you have that level of cost, the Home systems are designed to have continuous fan operation. Roof top RV AC/HP units do not have RPM needed safety systems. So, they can have whole RV fan operation. COST is the reason. Doug
Sam Spade
North Central Florida
Posted: 11/20/19 06:48am Link  |  Quote  |  Print  |  Notify Moderator
Under what conditions are you likely to use the gas furnace ?
When you don't have access to shore power and don't want to run the generator all night, maybe ??
The gas furnace is there mostly for use when on battery power only.
Running the fan continuously would accomplish little to nothing BUT would sap the batteries rather quickly.
It is designed that way on purpose.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
Johno02
Lexington, TN USA
Posted: 11/20/19 07:32am Link  |  Quote  |  Print  |  Notify Moderator
Understand your problem exactly, and the other reasons are all correct. We use two small Vornado fans, one on the doghouse in front, and one in the back bedroom blowing to the front. We have found that these make a lot of difference in keeping temps more even all over the coach. And it's a cheap solution.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and a grouchy, old, tiny dog
DrewE
Vermont
Posted: 11/20/19 07:54am Link  |  Quote  |  Print  |  Notify Moderator
Another reason why there is no continuous fan setting for RV furnaces is that the fan motor serves two purposes (there are two fans connected to the motor shaft). One fan is the circulator fan for the heated air, running on the house side of the heat exchanger. The other fan moves combustion air through the burner and heat exchanger on the other (outside) part of the heat exchanger. If there is no flame, the heat exchanger is going to be taking heat from the interior air and transferring it to the colder outside air. You'd be cooling the RV, not just circulating the air.
Household furnaces either don't have a fan on the burner side, relying on convection, or else have a completely separate blower assembly that can be controlled independently.
RoyF
Fayetteville Arkansas
Posted: 11/20/19 09:31am Link  |  Quote  |  Print  |  Notify Moderator
To address your concern about pipes freezing in the basement, why not get an external thermometer to put in your basement. Then you can keep tabs on how the basement temperature compares with the temperature outside.
If there really is a danger of freezing in the basement, you could allways use an (old style) light bulb near the pipes.
