RV.Net Open Roads Forum: Class A Motorhomes: Onan Gen--hard starting and surging
 > Onan Gen--hard starting and surging
RustyMacIntosh
Fresno, Cal
Posted: 11/20/19 07:01am Link  |  Quote  |  Print  |  Notify Moderator
I was gifted a 95 Bounder 34ft with the big block Ford engine. 30kish miles. Sat a lot.
I've resurrected it back to 90% operational. I've made several statewide trips.
The generator. At first, it would not start. Now it starts after cranking maybe 30 seconds from the dash. It will start up, run for maybe 5 minutes then you can feel it begin to surge.
Opening up the side panel, it's running, smoother now that at first. But then it surges. It gets worse and worse surging, then quits. It might attempt to start again but dies like it is out of fuel.
Let it sit for several hours, it does the same routine, cranks (longer than I like), then fires up, smooth then begins to surge ultimately dies.
OK--the coach has gone thru maybe 10 tanks of gas. Including filters and treatment. The 460 runs nicely.
I was once told that this unit has a fuel pump. So far, I have not located it.
I can see the filter which is connected to the carb. I tried yesterday to remove the filter but was unable to get the brass connector to free up from the bottom of the filter. I'm going to try it again today with heavier tools.
I think it is running a bit rich. Or at least that is what the exhaust pipe looks like. I do not see any blue or black smoke from the exhaust.
I'm thinking that maybe its time to just swap in a new carb, a new filter and all. Fuel pump? I guess if I can find it.
Its the Onan 5000 model btw.
DFord
Near St Louis, MO
Posted: 11/20/19 07:18am Link  |  Quote  |  Print  |  Notify Moderator
After years of setting the carburetor is probably gummed up. Replacing it may be the easiest fix. I've heard there are 3rd party carbs on eBay at reasonable prices. You'll need the model and serial and "spec" numbers of the generator to find the right part.
The fuel pump may be on the back side of the generator. The fuel line to the gas tank may have a crack allowing the fuel pump to suck air instead of gas after so many years. You can use a short piece of hose stuck in a gas can next to the generator bypassing the fuel line to see if that related to your problems.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
RustyMacIntosh
Fresno, Cal
Posted: 11/20/19 07:21am Link  |  Quote  |  Print  |  Notify Moderator
OK...going to study this genset a bit more. Also get some Seafoam. I think maybe trying to get the cleaner to ungunk it first before I buy a carb. Looks like Ebay does have aftermarket models.
rockylarson
Jersey Shore
Posted: 11/20/19 07:40am Link  |  Quote  |  Print  |  Notify Moderator
You might find that filter below the carb has been discontinued. There is another on the fuel line just before the fuel pump on the lower backside.
Jan and Rocky
Volunteers for USFWS. 25 refuges with 8000 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
rrupert
NW PA
Posted: 11/20/19 08:07am Link  |  Quote  |  Print  |  Notify Moderator
Small engines and 10% ethanol gas are incompatible. The carburetor could be all gunked up as a result. It could require a rebuild or replacement to make things right. After taking care of the carb try to find a way to run the generator with ethanol-free gas and maybe your problem could go away.
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
wildmanbaker
Kennewick, Washington
Posted: 11/20/19 08:49am Link  |  Quote  |  Print  |  Notify Moderator
Russ, your problem may be the fuel line from the tank to the gen. Get some fuel line the right size, and connect it to the inlet of the fuel pump. Then insert the other end in a container of gas of know quality, and start the generator to see if it will run. If it does, the fuel line from the tank to the metal line under the MH may have dried out and cracked, allowing air to enter the line causing the problems. It is possible to change the hose without dropping the tank, if you are not too muscled up.
Good luck
Wildmanbaker
ksg5000
Oregon
Posted: 11/20/19 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Most would agree that it's fuel related - likely gummed up carb and/or fuel filter or fuel pump. I would start with the gummed up carb since most rigs that sit have that in common. I would try the seafoam approach first - ain't fast but it's inexpensive and easy to apply. Small gas container with lots of seafoam can be connected to your fuel filter with small fuel hose - run the generator - let is sit - repeat.
Kevin
gbopp
The Keystone State
Posted: 11/20/19 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
I had a surging problem on the Onan 5000 in our 96 Southwind.
I used a can of Spray Seafoam. I removed the air filter. With the generator running I sprayed the Seafoam into the intake until it almost stalled.
I did that several times, then sprayed until it stalled and left it sit overnight. The next day it ran smooth.
Try that a few times, it's cheap and easy. Leave it sit several hours after stalling the generator with Seafoam.
I left it sit overnight because I was busy with another project.
RLS7201
Posted: 11/20/19 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
Your Onan NHM 7K generator has an adjustment on the bottom of the carb for different altitudes. Try turning the screw counterclockwise for a slightly richer mixture, and see what happens.
The ethanol in the fuel is actually a solvent that helps keep the carb clean. Remember when we used to add ethanol to our gas to help pass any water that was in our fuel tanks. Now we don't need to do that.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
RustyMacIntosh
Fresno, Cal
Posted: 11/21/19 05:19am Link  |  Quote  |  Print  |  Notify Moderator
My unit is a 5000, not a 5500. The carb faces the rear of the coach.
I never could get the brass connection to the bottom of the filter. So I cut the line leading to the filter, from there I removed the filter, blew out any fuel and gunk that might have been there.
After removing the filter from the carb, I pumped some SeaFoam spray down into the carb. Cranking the motor just briefly I could then determine the fuel pump is working...so the line was plugged with a bolt so I could crank the motor without getting a face full of gas.
I got it to start with the inlet fuel line loaded with Seafoam sorta kinda. I opened up the connection to the carb from the air filter, where I sprayed the innards also with Seafoam.
It ran better----smooth, after connecting back the inlet fuel line. UNTIL I put some load on it. Then the surge came back slightly, then got worse and worse until it quit.
I fired it back up, this time playing with the throttle, I am guessing that there must be a FAILSAFE that if the RPM's get too high the unit shuts off. I tried to get the RPM's up higher to see if it would self-clean with some fresh gas from the main tank, but nope...nada.
Opening the fuel line back up I poured more Seafoam into the line leading to the carb, where I let it sit for an hour. Again, it surged and finally quit.
SO.....I guess I will try one of those carbs off Ebay. I see I can get one for about $50-60 bucks. The swap looks easy enough. I am sure if I take it to the Cummins shop they will sell me a new carb at $400 plus labor.
One thing I did do is blocking the inlet gas line with a bolt, I checked after cranking to see if any of the leading gas lines from the main tank were wet indicating a crack. None.
**Footnote** The adjustment at the bottom of the carb for altitude, I have it set at Sea Level. If I turn it to 5000 or upwards the unit really does run rich.
I guess I could try some more carb cleaner, like BG or another product, but it appears whatever is going on with this Genset, the years of sitting in that storage yard has destroyed the carb just enough that it does not want to operate anymore.
