RV.Net Open Roads Forum: Tech Issues: Operating on a 20amp circuit
 > Operating on a 20amp circuit
Grey Mountain
On the rez somewhere in Indian Country
Posted: 11/21/19 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
Need to operate my rig for three or four days in early December. Will only use bare necessities in electricity. Lights mainly. Propane for heat, propane for water heater. In SW Oklahoma, it could get cold, but not seriously cold.
I think I should be OK on a 20amp circuit; however, I would like the opinion of others more knowledgeable than I, which is most of the known universe. I would have to use 20 to 30 to 50 doglegs.
GM
2006 Discovery 39S Tin Teepee
Honda CR-V Toad
Enrolled member of the Comanche Tribe
English Bride
Bichon Frise bear killers:
Lord Shonefeld von Reginald-Friese IV.
Lady Annabelle von Lichenstein-Friese III.
rockylarson
Jersey Shore
Posted: 11/21/19 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Yes it is doable. Basically you just need to keep your converter/charger on to supply the batteries. The heater fan is your biggest load in your scenario.
Jan and Rocky
Volunteers for USFWS. 25 refuges with 8000 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
ScottG
Bothell Wa.
Posted: 11/21/19 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
Delete
* This post was edited 11/21/19 08:19pm by ScottG *
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
ScottG
Bothell Wa.
Posted: 11/21/19 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
If you're going to use your propane furnace, you'll be fine. The fan uses less than roughly 60 watts, the fridge about 325. Water heater might push you over if run on 120VAC. If you're not worried about pipes freezing, you could get away with a space heater set to run at 750 watts. That would save a lot of propane.
Otherwise, you wont have any issues.
time2roll
Posted: 11/21/19 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
Put the fridge and water on propane and just run as you like.
Just stop the hairdryer before you run the microwave.
675w Solar pictures back up
Morro Bay, CA
Posted: 11/21/19 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
You can live like a king in cold weather on 20 amps.
winniman
muskoka Ontario
Posted: 11/21/19 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
I run my 50 amp bus on a 20 amp plug for over a week at hunting season. I plug into my friends garage outside plug. No problems with everything on propane.
opnspaces
San Diego Ca
Posted: 11/21/19 10:35pm Link  |  Quote  |  Print  |  Notify Moderator
Seriously you'll be fine even running the air conditioner. Just be aware that you can't run two high wattage devices at the same time.
High wattage devices:
  • Microwave
  • Air conditioner
  • Water heater on electric
You probably won't be using the AC so that just leaves two devices to be aware of. If your water heater is on electric then turn the switch off before you use the microwave. Other than that just don't worry about the electric uses and have a good time. @0 amps is plenty of power for your coach.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
valhalla360
No paticular place.
Posted: 11/22/19 02:58am Link  |  Quote  |  Print  |  Notify Moderator
You are perfectly fine based on what you describe.
20amp is fine unless you want to run the high amp devices (air/con, electric water heater and possibly microwave if it's a larger high wattage version).
You should be well within tolerances for a 20amp outlet.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Grey Mountain
Posted: 11/22/19 04:10am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies. We have visitors coming, and my rig will be parked outside my daughter's house. It will only be used for sleeping. As I said, furnaces and water heater will be on propane. Probably won't even turn the fridge on. None of the accessories wil be used - microwave, coffee pot, etc.
GM
