RV.Net Open Roads Forum: Fifth-Wheels: Lippert shock absorber replacement options
 > Lippert shock absorber replacement options
ivbinconned
highway 16
Posted: 11/22/19 09:25am Link  |  Quote  |  Print  |  Notify Moderator
Replacement 283271 Lippert shock is about $100 Canadian currency each at dealer or Napa.
Amazon about half that but will not ship to my location.
Options?
Ram and 34 ft Cedar Creek
ScottG
Bothell Wa.
Posted: 11/22/19 09:30am Link  |  Quote  |  Print  |  Notify Moderator
eTrailer.
There might be a Monroe equiv. as they make a lot of trailer shocks/kits.
* This post was edited 11/22/19 09:39am by ScottG *
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
Cummins12V98
on the road
Posted: 11/22/19 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Monroe 555001 GasMagnum for around $30ea.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ivbinconned
highway 16
Posted: 11/22/19 11:52am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Cummins. Just ordered them.
Cummins12V98
on the road
Posted: 11/23/19 07:31am Link  |  Quote  |  Print  |  Notify Moderator
GREAT!
I had then on two previous RV's and they were much better than the Chinese OE shocks.
Lynnmor
Red Lion
Posted: 11/23/19 10:15am Link  |  Quote  |  Print  |  Notify Moderator
ScottG wrote:
eTrailer.
I believe that Monroe discontinued trailer shock kits years ago.
Cummins12V98
on the road
Posted: 11/23/19 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
What's a "trailer shock kit" ?
sayoung
Tx
Posted: 11/23/19 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
Lynnmor wrote:
ScottG wrote:
eTrailer.
Monroe quit makeing the mounting kits but still make rv shocks. Our Jayco came with mounts but no shock. I followed Monroes instructions for measuring and my local auto parts guy matched up what I needed. I thought I still had the model but no can find.
It did make a difference on stuff moving around . However from vidideos on utube the Joyriders or whatever they are called would be the better way even tho more $. Having the mounts the shocks were worth it but if you have to go with the lci kit would go better.
ivbinconned
highway 16
Posted: 12/02/19 09:14am Link  |  Quote  |  Print  |  Notify Moderator
Ok Cummins about to install the number on the old is 122108.
The Munroe number 5550001 seems to be about 1/2 inch longer compressed.
Might this be a problem?
ivbinconned
highway 16
Posted: 12/02/19 11:21am Link  |  Quote  |  Print  |  Notify Moderator
More info. Obviously the old shocks were bottoming out as the cupped washers are driven down over the nut on the end of the tube.
I installed the new shock. Installed the wheel, let down the jack.
Now I measured the new shock with weight on it. It is with in 1/2 inch of bottoming out!!
Not good.
I’m considering this. Welding a short piece of angle iron onto the top bracket and adding 1/2 inch or perhaps a full inch distance between the to mounting positions.
This would also give a more vertical position to the shock too.
Thoughts?
