RV.Net Open Roads Forum: Fifth-Wheels: Lippert shock absorber replacement options
 > Lippert shock absorber replacement options
Cummins12V98
on the road
Posted: 12/02/19 11:32am Link  |  Quote  |  Print  |  Notify Moderator
ivbinconned wrote:
Ok Cummins about to install the number on the old is 122108.
The Munroe number 5550001 seems to be about 1/2 inch longer compressed.
Might this be a problem?
Monroe has a chart showing connection types and compressed/extended lengths. I doubt it would matter but check specs to be sure.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ivbinconned
highway 16
Posted: 12/02/19 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
Did you see my second post?
Ram and 34 ft Cedar Creek
sayoung
Tx
Posted: 12/02/19 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
I used a Monroe 555025.
ivbinconned
highway 16
Posted: 12/02/19 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
How did you arrive at that? Was your original a 122108?
ivbinconned
highway 16
Posted: 12/02/19 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
That shock would be even longer.
I phoned Monroe. The 555001 has 4 inches of play.
With new springs installed about 10,000 miles ago (and I added an extra leaf)
Now with the suspension bearing the weight of the trailer there is only about 3/4 inch of compression left!!
This can not be good. I phone Monroe. They tell me they like to see 60% possible compression left !!
ivbinconned
highway 16
Posted: 12/02/19 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
My Conclusion is this. Not enough distance was provided by brackets for original shocks. There for I am welding a new bracket on old one to add travel for the new shocks.
All original shocks show damage from collapsing to 0 plus.
Very poor quality work by manufacture.
ivbinconned
highway 16
Posted: 12/03/19 08:53am Link  |  Quote  |  Print  |  Notify Moderator
In fact drivers side rear the shock was with in 1/4 inch of full compression.
Shock absorber in looks only.
ivbinconned
highway 16
Posted: 12/03/19 09:05am Link  |  Quote  |  Print  |  Notify Moderator
So in effect the shock has acted as a limit to how high the axel can react to a bump up.
sayoung
Tx
Posted: 12/03/19 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
Tape measure. No OEM shocks just brackets . My axles are under Springs.
