RV.Net Open Roads Forum: Tech Issues: Charging electric car
 > Charging electric car
Page of 8
JRscooby
Indepmo
Posted: 11/24/19 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Lynnmor wrote:
joebedford wrote:
I guess I'm not explaining myself properly or my idea is just too stupid. The bus is dragging the toad down the road; the toad's wheels are turning; the toad's motor(s) are turning - throw in a little regenerative braking on the toad and its battery will charge. The bus has to work a bit harder but there is no modification to the bus.
That is a great argument for buying a toad that uses fuel.
I don't understand. AFAIK, the only reason against towing a E-car is warranty.
Reisender
NA
Posted: 11/24/19 09:00am Link  |  Quote  |  Print  |  Notify Moderator
Yah. Really it’s a matter of software and a brake pedal sensor for the Motorhome. Just a matter of someone writing it and the warranty thing.
Harvey51
Alberta
Posted: 11/24/19 10:20pm Link  |  Quote  |  Print  |  Notify Moderator
“one killowatt gets you about 6 ish kilometers in most EV's. ”
Unit confusion in this topic!
The kilowatt is not a unit of energy. It is a unit of power - how fast energy is consumed. Analogous to a gasoline car’s gallons per hour.
The unit of electric energy is the kilowatt hour. Analogous to gas car’s gallon of gas.
Driving an electric car a kilometre requires some amount of energy. How many kilowatt hours is it? How much does a kilowatt hour (KWH) cost? This is indicated on any electricity bill. It may be ten cents plus another ten cents delivery charge.
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
Reisender
NA
Posted: 11/24/19 11:04pm Link  |  Quote  |  Print  |  Notify Moderator
Yah my bad. One KWH gets you about 6 ish kilometers. Our lifetime average over four years in our one car is 6.7 Km per kWh. Electricity is about 11 cents per kWh where we are. Hope that clarifies it.
MrWizard
Traveling
Posted: 11/25/19 03:07am Link  |  Quote  |  Print  |  Notify Moderator
6 km is approx 4 miles,
Regulator gas is $3.599 st my local fuel up station, if you avg 20 mpg, then that's 18 cents a mile, 11 cents for 6 km/4 miles equals 2.75 cents per mile, a real bargain
The more you pay pet kwHr
The closer.the two become, the smaller the gain,
I think.around her 33 cents pet kwhr would be closer to it, making it about 11 cents per mile
Using an EV, still cheaper than gas
Radiate The Happy
1997 F53 Bounder 36s
JRscooby
Indepmo
Posted: 11/25/19 05:04am Link  |  Quote  |  Print  |  Notify Moderator
In normal driving of the EV, you want to slow, step on the brake, does the regen start then? And can you lift your foot from the go and whoa pedals, coast for some distance? (Remember, I know I'm ignorant.)
And most brake systems use some system to move brake pedal of toad? Any brake systems that do not use input from the MH brake pedal?
Unless I'm way off on any of this, I would say it would take very little change in programming, the technology is there.
Now I can see it would take some re-programming, but not a lot of change, for the toad to help the MH. And likely some changes to MH. (At least something to let the car know it is behind it's MH so it would not try to ride that close to another vehicle.
obiwancanoli
Napa
Posted: 11/25/19 07:24am Link  |  Quote  |  Print  |  Notify Moderator
We got a little off-topic here, but I've learned a lot... appears charging EV while being towed isn't a sensible option... thus, if one anticipates a lot of use while situated at chosen location, best to use ICE vehicle. EV charging while on the road appears less reliable...
Reisender
NA
Posted: 11/25/19 07:47am Link  |  Quote  |  Print  |  Notify Moderator
So yes. Kind of. As soon as you take your foot off the pedal max regeneration occurs. However moderating your pressure on the accelerator controls the amount of regeneration. This is how EV’s with “one pedal driving” are able to do that. Everything is controlled from the go pedal. Completely removing your foot causes quite strong regeneration and fairly strong decelation. It will actually bring you to a stop. However the software engages the service brakes for the last few kmh as regen fades away. Of course you can always still use your service brake pedal for even faster braking. Brakes don’t get a lot of wear in an EV. Brakes are good for the life of a car.
Hope that helps.
Reisender
NA
Posted: 11/25/19 07:54am Link  |  Quote  |  Print  |  Notify Moderator
It’s one of those “it depends” things. Although the US, Canada and Mexico are behind the rest of the modern world with charge infrastructure it is getting quite good even here. Tesla is still the king of the heap as they are designed to use any Chademo charge facility in addition to their own Supercharger network. But even those of us driving non Tesla’s have little difficulty finding facilities in “many” areas.
philh
Belleville MI
Posted: 11/25/19 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Your idea has merit...
However, the concept of towing 4 down is mostly a mystery to the OEM world, and specifically, in Electrification you typically have young people working at the OEM's.
Couple of things to overcome, what rate do you charge at, is it full charge over two hours at 55 mph? four hours? six hours?
Now you're also generating heat. How do you shed that heat? Remember, you typically don't have airflow across the radiator and no way to eliminate heat build up. What's the plan there?
Page of 8
