RV.Net Open Roads Forum: Fifth-Wheels: Help with water problem
 > Help with water problem
debili
Illinois
Posted: 11/25/19 11:53am Link  |  Quote  |  Print  |  Notify Moderator
Ok I did try it...what schlep1967 said and pressure was good through the water line when water turned on...
I am fairly sure it is the faucet however I am still going to wait to see if the guy comes by because I cannot get the hoses disconnected to event replace the faucet...geez
rjsd1
NW Georgia
Posted: 11/25/19 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
The pull out spray head line can develop a kink in the hose under the sink. Mine did this. Had to loosen and move the weight that's attached to the hose to keep line from kinking.
2016 F250 6.2 4wd
08 Crossroads Cruiser 30sk
salem
Central Valley, Ca
Posted: 11/25/19 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
Keep us posted on the outcome. I'd like to know what the problem/solution was in case I'm ever faced with the same problem.[emoticon]
salem
Central Valley, Ca
Posted: 12/04/19 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
I'd still be interested in knowing, as I'm sure others would, if you determined what the problem was.
winniman
muskoka Ontario
Posted: 12/04/19 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
Nine times out of ten, if it is a single lever facet, the cartridge inside is plugged or worn out. This can result in no hot, or no cold, or no water at all. They are easy enough to change. https://www.youtube.com/watch?v=ng484pwhBRI This video is for a moen tap. There are other videos on other tap makers. They are mostly similar.
debili
Illinois
Posted: 12/04/19 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
***UPDATE
so this is where I am at...I removed the old facet myself but had to get a guy to come and loosen one bolt to do so...bought a new faucet got it home and realized the fitting didnt work wrong size took it back returned it tried to find another with the long hoses to replace it the same way...ended up rebuying the same one I just returned...a man in the aisle said he was a plumber helped me find some brass fitting adapters that would make it work.
In the middle of all of this my great nephew was in a horrible car accident two days before thanksgiving, the day before after he was determined brain dead and my nieces family had to make a decision...
in the following two days my others nieces husband came and helped me with the faucet which when I got it all together was leaking... it seemed he had got it fixed but over night it leaked more he came again and tighten it up more more teflon tape.
That was two days ago.
In the meantime my family is in shock loosing this young man 18 so unexpected and senseless. He was hit from behind at high speed.
after the second fix the pipes are now leaking in a different place.
The wake was last night and funeral today. I talked to my nieces husband that had helped he didn't seem real excited to come and help again...it is leaking I have pan under catching water. It has been a rough few days and right now I cannot even concentrate or deal with it...
Once I get a second wind i will attempt to do something not sure what and will update again....
thanks all Deb [emoticon] [emoticon] [emoticon]
salem
Central Valley, Ca
Posted: 12/04/19 11:34pm Link  |  Quote  |  Print  |  Notify Moderator
Very sorry to hear about your great nephew. Hope all works out good for you.
philh
Belleville MI
Posted: 12/06/19 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
tough loss for the family. Every day is a gift.
Hire a plumber to fix this and be done with the issue.
garyp4951
TN
Posted: 12/06/19 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
I would be glad to fix it for you if I were closer to Illinois.
