RV.Net Open Roads Forum: Class C Motorhomes: Wiring Diagram
 > Wiring Diagram
RayZen
Washington
Posted: 11/25/19 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
The refrigerator isn't coming on, when plugged into 110VAC. I have checked for 12VDC right at the input terminals of the fridge, but there is nothing there, so it's obviously a voltage supply problem to the fridge, not a problem with the fridge, itself.
Next, I went to the converter and found that it is putting out the 12VDC like it's supposed to. So far, so good.
Finally, I went to the fuse panel on the outside of the RV, but there is no fuse labeled "Reefer" or "Refrigerator." (All of the labelled fuses in the panel were fine, anyway)
So now I'm at loss as to how to trace the wiring from the converter to the fridge, itself, since I don't have a wiring diagram for the RV. The owner's manual doesn't include such a wiring diagram.
Does such a wiring diagram exist, somewhere? If anyone has one and would be so kind as to snap a picture of it, I would be forever grateful. Or if anyone could guide me to where I might be able to purchase one, that would be likewise appreciated.
Thank you.
enblethen
Moses Lake, WA
Posted: 11/25/19 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Make and model of rig would help.
Make and model of the converter?
Fuses from converter are not normally outside. Many are behind metal plate adjacent to the 120 volt circuit breakers.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
cavie
Posted: 11/25/19 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Did you check the voltage at the converter with the batteries disconnected? If not you were measuring the battery voltage.
you are not gonna get a wiring diagrams unless you have a very high dollar RV.
Is there 120 volts to the fridge? Fridge 12 volt control circuit is shared by the furnace and the water heater.
Fulltimers
Anywhere, USA
Posted: 11/25/19 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
It's a tripped GFI outlet. Check in the bathroom.
If you own a Winnebago they will send you a complete set of schematics along with plumbing diagrams for free. At least they did for me back in 2000.
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2005 Saturn Vue (Mr. Toad)
3.5L V6 Automatic
DrewE
Vermont
Posted: 11/25/19 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
What fuse panel are you talking about--is it for the house loads, or is it the chassis fuse panel under the hood for things like the windshield wipers and marker lights?
I concur with your guess of a blown fuse or, failing that, a broken/bad connection in the 12V wiring. The 12V fuse panel for the house 12V loads is usually somewhere accessible from inside the motorhome, often ajacent to or a part of the 120V breaker panel. Whether the fuses are labeled adequately so you can easily figure out which controls the fridge is anybody's guess, but one of them would.
It probably would be worthwhile to do a quick check to see that the 12V ground connection for the fridge power is A-OK as well.
ScottG
Bothell Wa.
Posted: 11/25/19 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
Very few RV's are built to schematics. Just like a house, they are wired as needed.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
lane hog
Tucson, AZ & NW Chicago Burbs, IL
Posted: 11/25/19 11:19pm Link  |  Quote  |  Print  |  Notify Moderator
Winnebago and Itasca have wiring diagrams online you can download. Same for plumbing. Invaluable resources... but not all manufacturers seem to care about service after the sale.
  • 2005 Winnebago "Minnie" 31C (was a three-time Jayco owner)
  • 2012 MasterTow Dolly pulling a 2003 Jeep Liberty (had Ram 2500 CTD, Dodge Durango, Honda Odyssey...)
  • Onan Microquiet 4000, plus 130W solar and Honda EU2000i twins for backup
Chris Bryant
Arden, North Carolina
Posted: 11/26/19 06:15am Link  |  Quote  |  Print  |  Notify Moderator
More info would help, but if it’s a 3 way model it may be wired directly to the battery (through a fuse, of course).
-- Chris Bryant
bobndot
Posted: 11/26/19 07:28am Link  |  Quote  |  Print  |  Notify Moderator
RayZen, as suggested did you try the GFI ?
enblethen
Moses Lake, WA
Posted: 11/26/19 08:26am Link  |  Quote  |  Print  |  Notify Moderator
GFCI receptacle will not have effect on the 12 volt DC system. Converters should not be routed through a GFCI circuit.
 > Wiring Diagram
