RV.Net Open Roads Forum: Class A Motorhomes: Back up camera
Open Roads Forum  >  Class A Motorhomes  >  Projects & Upgrades
 > Back up camera
ferndaleflyer
everywhere
Posted: 12/01/19 09:07am Link  |  Quote  |  Print  |  Notify Moderator
I installed the VOX in my 36 ft DP yesterday and it did not send a signal to the screen in front. Went over and tested the wiring several times and nothing. I also moved the antenna to several locations with no results. I removed it and then installed it in my F-350 dually and it worked there. So it is my opinion that the distance and the fact that that there is a metal firewall back there obstructs the transmission. Could be wrong but I am sending it back anyway.
lilys
NC
Posted: 12/12/19 02:37am Link  |  Quote  |  Print  |  Notify Moderator
If you want to change a top quality backup camera for your vehicle,maybe this brand is one of your top options. Compared with well-known companies like Furrion and Voyager,the price is lower than theirs,but the parameter performance of the products is better than theirs. What's more,there are numerous reviews available at YouTube,I believe that you can find the one you like on it.
toptentech
united states
Posted: 12/22/19 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
If you want to leave this headache so check these ***Link Removed*** which are best for you. First, check this and read reviews about this and then you decide
JOERVDREAM
quincy, ca
Posted: 12/29/19 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
Tom/Barb wrote:
We spliced in a new camera. using a Kenwood CMOS - 130 and the wires in coach
I have an older setup tube type monitor and rear camera in my 05 that is in black and white. If I install a new camera and flat screen monitor that’s in color will the existing wiring work in color?
fcooper
St. Augustine, Florida
Posted: 12/29/19 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
Yes the existing wiring will work for color if you can find adapters or splice the ends.
Fred
Fred & Vicki
JOERVDREAM
quincy, ca
Posted: 12/30/19 08:07am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Fred
 > Back up camera
