RV.Net Open Roads Forum: Tech Issues: Built in vs. Stand-alone GPS?
 > Built in vs. Stand-alone GPS?
Page of 7
JaxDad
Greater Toronto Area
Posted: 11/29/19 05:42am Link  |  Quote  |  Print  |  Notify Moderator
valhalla360 wrote:
JaxDad wrote:
No, a dual SIM phone just ties you to 2 service providers.
What you want is an eSim with a global service provider.
This allows the phone to switch between different networks and work "locally" in other countries without changing sim cards.
That does work...but it's an expensive solution.
I’m paying LESS now than when I was on a conventional provider.
pnichols
The Other California
Posted: 11/29/19 10:23am Link  |  Quote  |  Print  |  Notify Moderator
JaxDad wrote:
Edited to shorten.
pnichols wrote:
Hmmm ... if an eSim card can be installed in an iPhone or an Android phone that ties one to a global service provider ... then:
1. Do you then get billed each month by the global service provider ... just like you would if you had a sim card locking your phone to one of the common U.S. providers?
2. If one uses their smartphone only in, say the U.S., but via a global service provider - then are you saying that wherever you are in the U.S. - your phone will connect to whatever specific U.S. providers' cell signal is the strongest at your particular location ... i.e. be it a Verizon tower, or an AT&T towers, or a SPRINT tower, etc. at the time?
If both the answer to both 1. and 2. above is "yes" ... then who are some 4G or LTE global providers that I could switch to, where can I find what plans they offer, and if there our some then WOW .... it seems like a no brainer to set up this kind of arrangement on my upcoming purchase of my first ever smartphone (to be Android based) so as to get best possible cellular signal coverage in the contiguous United States, Alaska, and Canada for RV travels?
(P.S. Unlimited and speed un-throttled from a global provider meeting the above requirements would be the ultimate - but that probably doesn't exist or is extremely expensive if it does exist.)
1. Yes, I get on bill each month.
2. Yes, my phone seeks out and jumps to the strongest signal, regardless of carrier. Every phone already jumps to the strongest signal, but only within the network it’s locked to, unless roaming. My phone is in a perpetual state of “roaming”.
I use GlobalSIM, I’m told there’s others, I just don’t know who they are. Global is the biggest.
It’s not expensive, I have 2 permanently assigned phone numbers (in my case one 416, one 305, both of which are always ‘live’) unlimited calling (no roaming charges, no long distance), texting and data (never throttled, no tethering restrictionists) almost anywhere in the world for $75 / month.
Thanks for your information follow-through .... I'm learning a lot, but it sure seems like a lot of research is going to be required if I want to break away from the comfort of good old Verizon (with it's expensive, limited full speed with unlimited data, good but not perfect, etc., coverage).
By the way, I notice that the GlobalSIM's coverage map seems to show vast areas of no coverage in Western U.S. places where we like to travel in our RV. Unless I'm interpreting the GlobalSIM's coverage map wrong - pure Verizon coverage my be better or at least easily equal GlobalSIM's coverage. I thought providers like GlobalSIM offered service that would jump between U.S. networks so as to automatically use the strongest signal ... hence easily providing service coverage well beyond what the Verizon-only coverage map shows?
Here's the GlobalSIM coverage map - which seems to show large poor/no coverage areas in the Western U.S.:
https://www.globalsim.co/coverage/
Phil, 2005 E450 Itasca Spirit 24V
JaxDad
Posted: 11/29/19 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
I saw that too, but routinely see that my phone is on the Verizon network, and have good service in those ‘black areas’.
I suspect the map is just out of date.
beemerphile1
Ohio
Posted: 11/29/19 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
valhalla360 wrote:
...All modern phones have a built in GPS that doesn't require a cell signal to locate the phone...
You should have seen me trying to explain that to the pimply faced nerd (geek squad) employees at Best Buy. They argued with me that having Copilot GPS app/maps loaded on my tablet won't work without a cell signal.
I regularly use my tablet for a GPS. My tablet doesn't have cellular capability.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Fizz
Ottawa, Canada
Posted: 11/29/19 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
iPads don't have GPS unless you get the one with cell service.
I know because we have one of each in the familly.
Other flavors of tablets might have GPS.
JaxDad
Posted: 11/29/19 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Adding GPS to a WiFi only iPad is easy & cheap..
I do the same thing, on-board GPS (terrestrial and aviation both) database files make for a really great big screen navigation unit.
GPS Thingy, clicky, clicky.
Fizz
Ottawa, Canada
Posted: 11/30/19 05:23am Link  |  Quote  |  Print  |  Notify Moderator
I bought this the year it came out.
https://gps.dualav.com/explore-by-product/xgps150a
Bill.Satellite
Full-timer
Posted: 11/30/19 05:24am Link  |  Quote  |  Print  |  Notify Moderator
Not sure about Co-Pilot (but I suspect it's the same), but Google Maps does not need cellular data as you can download your entire route with any available wifi before you leave on your trip. I recommend using data while you travel using your phone hotspot or MiFi device (your tablet does have WiFi capabilities) as this will also give you live, real time, traffic updates which can save you hours of drive time if there is a bad accident ahead. Stand alone GPS units cannot do this unless you are connected to WiFi or you are near a big city broadcasting the FM traffic signal.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
imgoin4it
Alamogordo, NM USA
Posted: 11/30/19 08:12am Link  |  Quote  |  Print  |  Notify Moderator
I like the stand alone unit (we use Garmin) because I can take it to my recliner , recline and plan the trip..
Howard,Connie,& Bella,
One spoiled schnauzer
2007 Newmar KSDP
4dr Jeep Wrangler
valhalla360
No paticular place.
Posted: 11/30/19 11:47pm Link  |  Quote  |  Print  |  Notify Moderator
How old are these ipads?
You can't find an android tablet without GPS anymore.
I know apple was slow to adopt it as standard as they were trying to use it as an option to increase price but I thought they gave up after it became an expectation even on cheap $50 tablets.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Page of 7
