RV.Net Open Roads Forum: Class A Motorhomes: Upgrade V-10 to Turbo?
Open Roads Forum  >  Class A Motorhomes  >  Projects & Upgrades
 > Upgrade V-10 to Turbo?
georgelesley
Tennessee
Posted: 11/28/19 08:24am Link  |  Quote  |  Print  |  Notify Moderator
I would not add a turbo as a stand alone mod. The exhaust manifold on the V-10 is iffy to begin with, adding more fuel males it hotter and will likely cause exhaust manifold studs, particularly the rear ones to fail quicker . Add a turbo to a Banks header system, lots of money but would have a better chance of success.
George & Lesley
2014 Itasca Sunova 33C, 2019 Jeep Cherokee Lattitude Plus toad, Demco/SMI towing system
ppine
Northern Nevada
Posted: 11/28/19 08:27am Link  |  Quote  |  Print  |  Notify Moderator
Or upgrade to a diesel. They have a turbo and inter-cooler already.
I agree that adding a turbocharger without other modifications is going add heat to your engine which is one of the main reason engines fail.
Gonzo42
California
Posted: 12/01/19 07:35am Link  |  Quote  |  Print  |  Notify Moderator
I was considering the Banks system. I see the 5 star tuner is illegal in the People's Republic of California. Just as a matter of discussion, if the 5 star tuner is installed, could it be removed for the smog testing and would it not permanently cause a smog test failure or would it revert to factory tune?
MOTHER SHIP Winnebago View 24H (2007 Dodge Sprinter 3500 Chassis, 2008 Body)3.0 L M-B Diesel V6 bought used with 24K miles. Toad: ROCKY the Flying Squirrel.
STBRetired
I-80 and I-55
Posted: 12/01/19 08:21am Link  |  Quote  |  Print  |  Notify Moderator
Gonzo, my 5-star tuner backs up the original factory tune and will allow me to revert back to it whenever I want. I can then put the 5-star tune back in at a later date. Here in the Land of Taxation, I can pass the emissions test with the 5-start in place. BIL runs a truck shop with an emission lane so we tried it just to see.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
Dale.Traveling
Newport News, VA
Posted: 12/01/19 09:29am Link  |  Quote  |  Print  |  Notify Moderator
A turbo V10 installed on a F53 is going to be a pretty rare item. I can't recall a kit type bolt on set up even for a F series truck let alone a F53. I'm sure it can be done but the cost will be high and the return low unless you're driving 10K+ miles a year in the Rocky Mountains.
2006 Hurricane 31D built on a 2006 Ford F53
time2roll
Posted: 12/01/19 09:41am Link  |  Quote  |  Print  |  Notify Moderator
Just want more power? Or some other drivability issues?
675w Solar pictures back up
RLS7201
Posted: 12/01/19 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe you could do to your V10 like I did to my 460 Bounder. Add a stroker crank, RV cam, raise the compression ratio, Banks exhaust & a tuner. Never too much HP...................
Richard
wildmanbaker
Kennewick, Washington
Posted: 12/01/19 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
Rich, where are you finding these parts? Then there is the balance problem.
Wildmanbaker
MrWizard
Traveling
Posted: 12/01/19 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
He turned a 460" into a 528"
68 Cu inch gain, almost 15% displacement increase
Parts for the 460" are readily available, if you have the $$
I think the v10 is a more complicated engine
But I'm an electrician Not a Mechanic
Radiate The Happy
1997 F53 Bounder 36s
dodge guy
Bartlett IL
Posted: 12/01/19 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
Richard
The only thing I know of that is available are cams........and they cost around $1000! A crank would be custom. Performance Pistons and rods from a 5.4 are a direct fit. No aftermarket heads available, and again head work would be pricey and not worth it for the minimal gains they would give!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
