RV.Net Open Roads Forum: Fifth-Wheels: Water heater question
 > Water heater question
importman
Lake City,SC
Posted: 11/27/19 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
Hello again everyone, I have another question. My Montana has a Suburban water heater and I’m wanting to replace the anode rod with one that has a drain made on it. It’s cold here in the NC mountains so I have to winterize every time we come for a weekend and I’d like to speed up the process. My problem is that the rod that’s in it now is about 8 inches long and all I can find with a drain are about 4.5 inches long. Other than having to replace it more often is there any reason I couldn’t use one like that? They both have 3/4 pipe thread. Thanks in advance for your help.
enblethen
Moses Lake, WA
Posted: 11/27/19 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
I would stay with the standard anode. Buy the proper sized socket, extension and ratchet to make it very easy to remove and install.
The small drains can and will clogg up. You may think you drained the tank but guess what, you didn't!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
All I could afford
North jersey
Posted: 11/27/19 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
I don’t think it will be any issue. I had never heard of that type of Anode rod, now I have to look it up
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollin’ on 33’s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
Owens River Road, California
Posted: 11/27/19 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
I’ve found it takes forever to drain with those.
wildtoad
Blythewood, SC
Posted: 11/27/19 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
I think you’ll need a wrench that allows for the valve. I have looked at those anode rod/drain combos and have never found one for a Suburban. They have all said for Atwood. So be sure.
* This post was edited 11/27/19 05:40pm by wildtoad *
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
bob213
Fresno, CA
Posted: 11/27/19 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
As the anode rod breaks down it drops a lot of particles in the bottom of your tank. I don't believe you will ever fully drain/flush your tank using the rod with the drain.
All I could afford
North jersey
Posted: 11/27/19 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
But the valve will be likely good enough for a routine weekly drain, between uses, as long as it got the occasional full flush with the anode run out.
Veebyes
Posted: 11/27/19 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
Never seen the short anode however a short one is better than none I guess. I give mine a good flushing once a year at the end of the season. Removing the anode to drain is faster & no big deal as long as you have the socket & short extension.
2007 Alpenlite 34RLR
MFL
Midwest
Posted: 11/27/19 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Without seeing the short one with drain, I'd say if the drain hole is smaller, it will plug up, not drain well. Between outings, I often drain my Suburban WH just using the low point drain. It drains just as well as removing the plug, as I checked by removing plug afterward, and water was at bottom of plug hole, but none came out.
I would not use anything but the Suburban brand OEM plug, but that's just me.
Jerry
enblethen
Moses Lake, WA
Posted: 11/27/19 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
Here is one Anode with drain valve
