RV.Net Open Roads Forum: Beginning RVing: pressure washers
 > pressure washers
stargirl96
Weatherford, OK
Posted: 11/27/19 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Do any of you use a pressure washer to clean your RV? Is it harsh on the finish and decals? Seems like it would be useful to wash an RV, especially when you don't want to climb a tall ladder. I noticed one of the Black Friday flyers has one advertised at a good price.
Johno02
Lexington, TN USA
Posted: 11/27/19 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Works great if used carefully.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and a grouchy, old, tiny dog
Morro Bay, CA
Posted: 11/27/19 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
Use very carefully. Better to soap the sides gently and rinse...but “back off” if using water under high pressure. For the roof, follow manufacturer’s recommendations. Winnebago says to clean my roof yearly, after which I seal seams, solar panel feet etc.
DutchmenSport
Indiana
Posted: 11/27/19 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
Never used a pressure washer on any of my RVs. But I've used them to strip paint off wooden fences. For this reason I've never used one on my RV's. Get the nozzle too close and there goes a hole in my fiberglass wall!
Veebyes
Posted: 11/27/19 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
I would not worry too much if it is only a 1500PSI, usually electric, washer however I would not waste money getting one that weak.
I have a 2500PSI gas washer used primarily for boat bottoms, house roof, concrete driveway. Effective but nowhere near a good as a 3000 or a 5000PSI. Get yourself a nice soft brush, a decent length adjustable painters staff from Lowes or somewhere, a bucket of of soapy water & go at it.
Much more effective & safer for the graphics than a pressure washer. The only time mine has seen a pressure washer is in TOK, Alaska at a fuel station there where you can wash your RV after you buy fuel. Feels like a 3000PSI but I keep my distance & use it to get the chunky bits off then rinse after brush & soap.
2007 Alpenlite 34RLR
Edd505
Elephant Butte, NM
Posted: 11/27/19 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
Used an electric 1500 on the roof this year, worked great. Added Oxiclean to the soap water, soft brush, pressure washer rinsed and it's like new. I'll keep the gas for the truck, shop & driveway.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
craig7h
Branson MO area
Posted: 11/28/19 03:56am Link  |  Quote  |  Print  |  Notify Moderator
I have always used a pressure washer on my units. I do however make sure of a couple things. Try and go with the graphics so as not to get under the edge. I always use the fan type spray never the full pressure one.
Over the years I have never seen a problem. I put a diluted turtle wax, wash and wax product in the soap reservoir. Wet down the a part of the rig spray the wash and was on. I then use a brush made for RVs to help remove the dirt. Rise off and go to next section, and so on
Itasca Meridian SE 36g
Road Master Tow Dolly
JimK-NY
NY
Posted: 11/28/19 05:33am Link  |  Quote  |  Print  |  Notify Moderator
I have never heard of anyone attempting to clean their car with a pressure washer. If no one using it on a car, why try with an RV?
Several years ago I put a ZEP finish on mine. I add an additional coat every year or so and the RV washes clean easily.
wildtoad
Blythewood, SC
Posted: 11/28/19 06:29am Link  |  Quote  |  Print  |  Notify Moderator
IMO pressure washer will do a decent job of getting into little areas that you might miss with just a hose and mitt but doesn’t get it really clean. I get the same almost clean when taking car through a no touch or DIY spray car wash. If I have to use a brush or mitt, bucket of soapy water and hose why bring out the power washer?
Tom Wilds
Blythewood, SC
pianotuna
Regina, SK, Canada
Posted: 11/28/19 06:34am Link  |  Quote  |  Print  |  Notify Moderator
If using a pressure washer, it would be good to wax the RV afterwards.
My pressure washer was something I had to walk away from when I moved to full time--just not enough storage for it to come with me.
Regards, Don
 > pressure washers
