RV.Net Open Roads Forum: who uses Fog lights? / Hella 500 / OEM connector->F350
 > who uses Fog lights? / Hella 500 / OEM connector->F350
LosAngeles
Los Angeles, CA
Posted: 11/27/19 10:19pm Link  |  Quote  |  Print  |  Notify Moderator
Hi all
So I am curious to know how often do people use Fog lights?
I live in the midwest now (just moved here) and if I was camping, and the fog was really bad… I would wait it out.
I am likely going to get an aftermarket front bumper for our forthcoming new F350, so I would lose the stock Ford fog lights.
If I really should have fog lights…… (?)
For $105 Aluminess will mount a pair of Hella 500 fog lights in the bumper
“ They shoot a short, wide beam that is perfect for cutting through fog.”
and have wire coming off them. Understandably they will not hook them up to my truck.
(I want to leave the stock bumper intact, and not cannibalize the OEM Fog light wiring harness on it, so I can easily put the stock Ford bumper back down the road, if need be)
I’d need to ideally find the correct female (?) connector to connect to the bare wires coming from each Hella 500 so I could plug them in, in place of the OEM stock Ford fog lights.
Anyone know the actual connector Ford uses?
Either that or I could buy an OEM wiring harness and splice the Hella 500 wires into it.
i THINK (but not sure if) it is Ford Part # HC3Z-15K867-B (about $30-$40-ish.)
Not sure this is the correct Ford Superduty 2019 fog light harness…. I think i may have been told the wrong part #
Thoughts? Advice? thanks!
Here is the bumper I will likely get:
https://www.aluminess.com/ford/ford-trucks-2017-current-front-winch-bumper/
ScottG
Bothell Wa.
Posted: 11/27/19 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
You're going to put a porch on the front of your truck? [emoticon] [emoticon]
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
PartyOf Five
Wheaton, IL
Posted: 11/27/19 11:02pm Link  |  Quote  |  Print  |  Notify Moderator
We added for lights and had them wired in, then we added another aftermarket light: an LED light bar about 24" long. This is what I'd suggest- it came with an easy wiring harness and puts out 3000 lumens. We bought it at Canadian Tire, so look around and you might be surprised what's out there.
Da Moose:2001 31' E450. 30k in 3yrs- 45 states, 9 provinces
PartyOf5: Driver's DW & 3 pre-teens -trying to connect, learn, appreciate creation & the Creator
May you find Peace in all that you endeavor
pbeverly
South Carolina
Posted: 11/28/19 04:36am Link  |  Quote  |  Print  |  Notify Moderator
Both of my vehicles came with them, they are awesome when the fog is thick.
Ridgeway, SC
mich800
Pontiac, MI
Posted: 11/28/19 06:12am Link  |  Quote  |  Print  |  Notify Moderator
I think the connecter is built directly into the back of the oem light. You will need to find a similar connector or just splice in new connectors into the stock harness. You could keep the ends if you ever want to remount the stock lights.
whjco
Lexington, KY
Posted: 11/28/19 08:58am Link  |  Quote  |  Print  |  Notify Moderator
Just make sure that the light bar is street legal as many are not. My concern would be blinding other drivers with a light bar.
Bill J., Lexington, KY
2006 Starcraft 2500RKS 25' Travel Trailer
2015 Ram 2500 Big Horn 6.7 Cummins.
Boomerweps
Hills of PA
Posted: 11/28/19 09:46am Link  |  Quote  |  Print  |  Notify Moderator
IMHO, strongly consider just selling off the OEM bumper assembly. Once you modify your truck, you will not likely want to bother to change it back EVER.
So use the existing harness, buy a new one, or just splice the connector that comes with the new fog lights into the existing wire harness, like we always did 30 years ago adding fog lights [emoticon]
2019 Wolf Pup 16 BHS Limited
2019 F150 SCrew STX SB 5.0 factory tow package
TenOC
On the road -- Full time
Posted: 11/28/19 10:30am Link  |  Quote  |  Print  |  Notify Moderator
I use my fog lights ALL the time when driving on non-interstate or city streets.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
Posted: 11/28/19 10:33am Link  |  Quote  |  Print  |  Notify Moderator
You can find most any OE type connector online. Deutsch, weatherpak etc type connectors. Dunno specifically what is used for ford driving lights.
Probably find pre made connectors or adapters as well. Agree, I could re wire most anything as good as OE, but sometimes it's quicker, easier, and cleaner to plug n play.
Sell the OE bumper, IMO. Truck bumpers sell easily and for good money. Bout the only vehicles that still have "replaceable" bumpers anymore.
Regarding the need for fog lights? This is a preference or "need" that anyone who's been driving for more than a year? can prolly figure out for themselves.
But since you're asking the Internet what your preference should be, I'd replace the OE driving lights with a similar low beam/ low angle type LED that works for lighting up directly in front of the truck and slap a nice light bar on the cow catcher for driving where things go bump in the night!
RGar974417
Robesonia,Pa 19551
Posted: 11/30/19 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Fog lights are kind of like 4 wheel drive.Better to have them and not need them than to need them and not have them. I have had them on several trucks and they are great when needed. Having said that, they only get used a few times a year.
