RV.Net Open Roads Forum: Tech Issues: FURNACE NOT LISTED ON THERMOSTAT
 > FURNACE NOT LISTED ON THERMOSTAT
NoSnowInAZ
wherever
Posted: 11/27/19 11:23pm Link  |  Quote  |  Print  |  Notify Moderator
DELETE
* This post was edited 12/02/19 10:35am by NoSnowInAZ *
As Always..HAPPY MOTORING!
Golden Pup "Molson"
Golden "Summit" - left us wonderful memories 2/11/08
02 Allegro Bay 36
2013 Jeep Wrangler Sahara Unlimited
FMCA
FULL TIME
Never thought it would happen!
12th Man Fan
Flower Mound , Texas
Posted: 11/28/19 06:57am Link  |  Quote  |  Print  |  Notify Moderator
The dip switches in the roof units determine what shows up on the thermostat. If you have not made any changes in the roof units then I suspect you are right about a bad control board.
This is for Dometic units. Not ssure of other brands.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
dougrainer
Carrolton, Texas
Posted: 11/28/19 08:19am Link  |  Quote  |  Print  |  Notify Moderator
If you have Dometic(2002) Tiffin was using Dometic. I have NEVER seen a upper control board be bad and not show a function. Odds are, the upper control board Furnace DIP switch needs to be turned Off then ON, to verify communication. IF you have had a repair on the front AC recently, then the Installer may not have turned the Furnace DIP switch ON. Doug
NoSnowInAZ
wherever
Posted: 11/28/19 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Hi Doug. Where would that upper control board dip switch be? Happy Thanksgiving!
NoSnowInAZ
wherever
Posted: 11/28/19 09:25am Link  |  Quote  |  Print  |  Notify Moderator
dougrainer
Carrolton, Texas
Posted: 11/28/19 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
https://pantherrvproducts.com/dometic-du........Os-qN5gIVSb7ACh1lyQRREAQYASABEgIO0fD_BwE
The red block with the 8 whites switched is it. Pin number 4 is the furnace. Doug
Bobbo
Wherever I park
Posted: 11/28/19 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
My TT air conditioner died before I ever took the trailer out for the first time. Dometic had a bad run and I got lucky. When the dealer replaced it under warranty, I brought it home and did my usual OCD double checking. I saw that the furnace was no longer listed in the thermostat. I took it back to the dealer and the service guy spent 2 hours trying to figure it out. Then he called the service manager over. As soon as he explained what was happening, the service manager told him the dip switches inside the roof unit were set wrong. Took 5 minutes more to fix, and most of that was getting the ladder.
Bobbo and Lin
NoSnowInAZ
wherever
Posted: 11/28/19 11:54pm Link  |  Quote  |  Print  |  Notify Moderator
I can see how that could be it but nothing has been changed. This happened all of a sudden. I have a new furnace board coming in tomorrow so hoping that'll do it.
dougrainer
Carrolton, Texas
Posted: 11/29/19 07:28am Link  |  Quote  |  Print  |  Notify Moderator
If you are saying you have a FURNACE board coming and NOT an AC board, you just wasted your money. WHY do people come to these forums for help(they obviously know nothing), get advice and then do what they want anyway?????????????????????????????????????????? Doug
NoSnowInAZ
wherever
Posted: 11/29/19 07:49am Link  |  Quote  |  Print  |  Notify Moderator
Doug, SIR -I had no service work done on the AC unit - no dip switches had been changed by either me or any tech.
Must be an incredible feeling to be so GD perfect. Find another forum to "help out" with your valuable assistance.
