RV.Net Open Roads Forum: General RVing Issues: Oxygenics Fury RV Handheld Shower
 > Oxygenics Fury RV Handheld Shower
dpgllg
South West Pennsylvania
Posted: 11/28/19 07:01am Link  |  Quote  |  Print  |  Notify Moderator
The handheld shower head in my 5th wheel broke on our last trip and I'm looking to replace it.
On our old 5th wheel I installed an Oxygenics shower head and everyone loved it. My wife and daughters said that it provided enough flow for them to really rinse their hair.
When looking online I see that there is now a Oxygenics Fury RV Handheld Shower Head available. Has anyone installed one of these and is it as good or better than the original?
I won't be needing it anytime soon as the 5th is stored away for the winter but would like to have it ready when Spring comes along.
2013 2500HD Chevy LTZ 6.6 Diesel Ext Cab Long Bed
2017 Grand Design Reflection 27RL 5th Wheel
Dear Wife, plus two Cocker Spaniels and a Standard Poodle
ependydad
Here and there
Posted: 11/28/19 08:53am Link  |  Quote  |  Print  |  Notify Moderator
I’ve had both an original (Body Spa) and a Fury.
The Fury has multiple spray patterns but doesn’t boost low pressure as the Body Spa.
The Body Spa boosts water better but doesn’t have multiple spray patterns.
For my family, we prefer the adjustability of the Fury and that’s what stayed in the shower. Every once in a while, I wish we had the Spa but if pressure is that bad, we’ll fill the freshwater tank and will run off of the pump (which does a pretty decent job!).
2017 Spartan 1245 by Prime Time
2012 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: B&W Turnover Ball + Companion
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
cavie
Posted: 11/28/19 10:22am Link  |  Quote  |  Print  |  Notify Moderator
I use the body spa. Love it.
JimK-NY
NY
Posted: 11/29/19 08:57am Link  |  Quote  |  Print  |  Notify Moderator
An Oxygenics shower head uses about 1 1/2 gallon per minute. I use a shower head with a slow gentle stream. I use about a gallon for an entire shower. If you need to conserve water, an Oxygenics is a poor choice. If you are using hook ups then it doesn't matter.
dcmac214
SW OKLA
Posted: 11/29/19 10:02am Link  |  Quote  |  Print  |  Notify Moderator
Shower head heretic here. A shower head is a shower head. Some have one spray, others have multiple sprays. There's nothing magical that makes an Oxygenic any better or worse than any other brand. It's just another shower head.
ependydad
Here and there
Posted: 11/30/19 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
How much hair do you and your family have?
drsteve
Michigan
Posted: 12/01/19 07:28am Link  |  Quote  |  Print  |  Notify Moderator
Just another shower head, but it works way better than the OEM junk from the RV factory.
1991 Palomino Filly PUP
JimK-NY
NY
Posted: 12/01/19 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
My hair is medium length and I can still wash it and rinse along with the rest of my body with about a gallon of water. My wife has shoulder length hair or perhaps a bit longer. She probably needs another quart of so to rinse it but she typically does not wash it everyday.
My point is simple a shower head which uses a gallon or more a minute is going to waste a lot of water. When it is important to conserve we do so by wetting down, soaping and then rinsing with a gentile stream of water. If water conservation is not important then turn up the water flow and any shower head can be used.
AirSupport
Boondocking somewhere in N. America
Posted: 12/01/19 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
Completely false.
ependydad
Here and there
Posted: 12/02/19 11:09am Link  |  Quote  |  Print  |  Notify Moderator
It sounds like you both have relatively short hair. I have the shortest hair of my wife, daughter, and I and it's probably 2-3" below my shoulders. It's thick- think Fabio type hair. [emoticon]
My daughter is next with hair a bit longer.
And my wife's is even a bit longer than that.
All three of us have very thick hair.
We use LESS water even with a higher flow due to the extra pressure of the water actually getting through the hair vs. a crappy shower head that doesn't seem to help boost the water.
I know it's hard to imagine, but it truly does make a difference.
