RV.Net Open Roads Forum: Have no electrical power and no propane on one side of coach
 > Have no electrical power and no propane on one side of coach
Page of 5
majordad
carson city, nv
Posted: 11/29/19 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Need help, 1800 miles from home, I have lost the 120 volt power on passenger side of my 2001 Fleetwood Discovery and the propane does not work to the heater or refrigerator. The other day I started the coach as the batteries were low and let it run for about 15 minutes. I also Reset the a/c out 1 and 2 on the inverter and when I checked the bathroom lights, they came on. I releveled the coach and shut off the engine. As it got dark, I turned on the heater and it was working fine. Came back later to put the boys to bed and heater was blowing cold, ignition failure on the hot water heater and again no lights in bathroom..
Any advice as to what is wrong, we need the heater going home as it will be colder.
Merrill
* This post was edited 11/29/19 10:32am by majordad *
rgatijnet1
Posted: 11/29/19 10:35am Link  |  Quote  |  Print  |  Notify Moderator
The power issue is either a GFI outlet that has tripped or the inverter. These are the outlets with a red reset button on them. You may have only one or two on your coach.
The other thing to check is the circuit breakers on your inverter itself. Most usually have two circuit breaker buttons that can trip. These are on the inverter and NOT in your main circuit breaker power panel.
I should have added that your salesman switch, usually by the door, may have be switched off which would keep 12 volts from going to either the WH or the furnace. With no 12 volts, neither will work.
rk911
DuPage County
Posted: 11/29/19 10:38am Link  |  Quote  |  Print  |  Notify Moderator
regarding the power...
- 50 amp or 30 amp coach?
- check for a tripped GFCI outlet in the kitchen, bath. your power out on one side almost screams a tripped GFCI
- if that's not the problem disconnect from shore power and start the genny. if all electric is working your problem is likely at the post. if problem persists you may have missed a GFCI
ref the LP...simple things first...
- lp tank full or at least not empty? supply valve on?
- was furnace working before?
- will the stove light?
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
majordad
carson city, nv
Posted: 11/29/19 10:53am Link  |  Quote  |  Print  |  Notify Moderator
Merrill
What is the salesman switch , what does it look like
majordad
carson city, nv
Posted: 11/29/19 10:55am Link  |  Quote  |  Print  |  Notify Moderator
50 amp service, 2 switches on inverter, do not act like breakers, no click when moved, could 1 of those be bad
rgatijnet1
Posted: 11/29/19 11:00am Link  |  Quote  |  Print  |  Notify Moderator
Switch the 50 amp breaker on the RV park power pole. You may have lost just one leg of the input power. The salesman switch shuts off basic power inside the coach and sometimes gets bumped to the off position. Most are right near the front door.
enblethen
Moses Lake, WA
Posted: 11/29/19 11:04am Link  |  Quote  |  Print  |  Notify Moderator
Many Fleetwood products have a solenoid to turn the propane off at the tank. Check propane detector to insure it is on
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
dougrainer
Carrolton, Texas
Posted: 11/29/19 11:13am Link  |  Quote  |  Print  |  Notify Moderator
They are NOT called Salesman switches. They are called Battery Disconnect Switches. Doug
MarkTwain
Northern, Ca. , USA
Posted: 11/29/19 11:28am Link  |  Quote  |  Print  |  Notify Moderator
A long shot but----I had lost power to one side of my 5th wheel, after have the tech check all electrical systems, he went and unplugged the 50 amp shore line cord and then pushed it back on . The problem was that when I plugged in my shore line cord, I did not push it in all the way!!!! Easy fix but another one of those operator dumb mistakes by me!!!!
cavie
Posted: 11/29/19 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
You are 100% correct Doug. Unfortunately the Majority of MH owners don't know any better. I don't think it is ever gonna change. I would love to hear one of them go to a hardware store and ask for a salesman switch.
It's like MH owners saying they have an RV and the rest of us have......I don't know, tents with wheel I guess.
Page of 5
