RV.Net Open Roads Forum: Have no electrical power and no propane on one side of coach
 > Have no electrical power and no propane on one side of coach
Page of 5
CA Traveler
The Western States
Posted: 11/29/19 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Whatever the official name of the "salesman switch" is it doesn't completely disconnect the house battery from all of the loads. Mine disconnects some common loads like lights but not the refer and not other safety items.
Maybe it should be called "Battery Draw Reduction Disconnect Switch".
Even my 2 Monaco installed Battery Disconnect Switches (real mechanical switches) don't disconnect all loads from each battery bank. But the Battery Disconnect Switches I installed do indeed completely disconnect the batteries from all loads.
Correct terminology or not "Salesman Switch" uniquely identifies the small switch by the door that activates the latching solenoid near the batteries that disconnects some loads.
2014 Grand Cherokee Overland
Bob
Old-Biscuit
Verde Valley
Posted: 11/29/19 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
Salesman Switch
COMMON nomenclature used by MANY folks
Some folks just love to appear superior by denigrating others
RLS7201
Posted: 11/29/19 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
Some one on the internet mistakenly call the battery disconnect switch a salesman switch because they saw a salesman using it and now it's an internet truth. Geeeeeesh......
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
majordad
carson city, nv
Posted: 11/29/19 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
IS IT POSSIBLE FOR THE INVERTER TO BE BAD ON ONE SIDE AND GOOD ON THE OTHER
rgatijnet1
Posted: 11/29/19 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, but not likely for a bad inverter. Check the simple things first. Do you have a voltmeter to check that both 120 volt legs of your 50 amp service have power. This could be something as simple as the campground 50 amp breaker, or a loose wire in your power cord at either end. If you do not have a voltmeter, try to find someone that does and have them check to make sure that you have 120 volts at EACH input leg of your main circuit breaker in your electrical panel. It could be a bad transfer switch a loose wire but all of that is just guessing without a voltmeter. My coach had a GFI circuit breaker in one of the basement compartments which is easy to overlook.
If I used the wrong word for anything, I hope someone will correct me rather than helping the OP. [emoticon]
cavie
Posted: 11/29/19 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
Salesman Switch
And some folks just try to help the newbies learn a language they are new to and know nothing about.
rgatijnet1
Posted: 11/29/19 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
And some folks just like to post and still offer no help to the newbie with a problem. Right now he is trying to get his electrical issues fixed. Don't you think it would be best to get the problem fixed and then have a vocabulary lesson later? [emoticon]
He is 1800 miles from home, it is cold there, and he does not have his furnace.
midnightsadie
ohio
Posted: 11/29/19 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
if you don,t get it fixed? might ask some one in your camp. or look up a rv mobil tech in that area. gfi should click when reset. let us know if you get it fixed,might help some one else in the future.
cavie
Posted: 11/29/19 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
Majordad, did you find the Battery Disconnect at the door. Your lights are 12 volts. Your furnace has two 12 volt circuits, One for the fan motor and one for the control board. The same 12 volt circuit for the control board is shared with the WH.
CA Traveler
The Western States
Posted: 11/29/19 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
What batteries were low? Chassis or house? Your post implies the house batteries are not being charged. Low house batteries can cause various and strange problems.
A $10 voltmeter is your friend and can REALLY HELP understand the problem. Per your post a 15 minute charge from the alternator is a bare minimum charge as it can take several hours to get the batteries up to mostly charged. Hence the lights etc when out again.
Please post the battery voltage of both banks.
Loss of AC could be a GFCI or some other loss of AC possibly on one leg of the 50A. Again a voltmeter is your friend. However probing AC can be dangerous and I recommend you get help for AC checking.
majordad wrote:
The other day I started the coach as the batteries were low and let it run for about 15 minutes. I also Reset the a/c out 1 and 2 on the inverter and when I checked the bathroom lights, they came on. I releveled the coach and shut off the engine. As it got dark, I turned on the heater and it was working fine. Came back later to put the boys to bed and heater was blowing cold, ignition failure on the hot water heater and again no lights in bathroom..
Page of 5
