RV.Net Open Roads Forum: General RVing Issues: jack pads
 > jack pads
craig7h
Branson MO area
Posted: 11/30/19 03:15am Link  |  Quote  |  Print  |  Notify Moderator
I was parked in a field for a rally when it rained and rained some more. The yellow lego things sunk may be 2+ inches. I was lucky to get the jacks up.
When home and ordered Jack pads from Outrigger (bigfoot) and are they great. I got the 15x15x1.5 and can not be happier. I would check them out. https://www.outriggerpads.com/for-rvs/
Itasca Meridian SE 36g
Road Master Tow Dolly
Wherever I happen to park
Posted: 11/30/19 05:53am Link  |  Quote  |  Print  |  Notify Moderator
Well my jacks are .. non-op.. So I use 2x12' by 3 feet for leveling the RV.
I also have 2x12x12's
I would suggest 2x12 squares for the first try and if that don't work go to 2x12 by 3 feet long.
Home is where I park it.
Slownsy
Posted: 11/30/19 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
We use 3x8” pressure treated pine 12-14” long great for leveling also on sloping sites as we mainly camp of sites.
Frank.
Frank
2012 F250 XLT
4x4 Super Cab
8' Tray 6.2lt, 3.7 Diff.
Hammerboy
Zeeland, MI
Posted: 11/30/19 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
I use these for our fifth and come in many sizes
Footing Pads
Dan
2019 Chevy crew LTZ 2500 HD Duramax
2017 Wildcat 29rlx fifth wheel
Veebyes
Posted: 11/30/19 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
Footing Pads
Dan
I don't doubt the effectiveness of those things but one can buy a whole pile of damaged but perfectly suitable wood for the price of those.
2007 Alpenlite 34RLR
Posted: 12/01/19 01:32am Link  |  Quote  |  Print  |  Notify Moderator
Then use plywood if 2x12s won't work for you. Not rocket surgery.
Hammerboy
Zeeland, MI
Posted: 12/01/19 06:31am Link  |  Quote  |  Print  |  Notify Moderator
Veebyes wrote:
Footing Pads
Dan
That may be but they are a lot cheaper than Snap Pads. I have mine permanently fixed.
Dan
CFerguson
on the road
Posted: 12/01/19 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
I use the engineered composite plastic decking boards- thickest ones I can find. If you need the wider than you can find, place them side by side and then stack the next layer 90degrees to the previous one.
STBRetired
I-80 and I-55
Posted: 12/01/19 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
I took a 4' x 8' sheet of 3/4 CDX plywood and cut it into 18 16" x 16" squares. Glued ans stapled them together in pairs with a piece of old ratchet strap sandwiched in between to make a handle. Gave me 9 16" x 16" X 1.5" pads. My rig is only 22K so no issue at all. I loaned some to a friend whose rig weight out at about 34 and he had no issue with them either. Had them sink in a field when we got 2 days of rain but handle made them easy to pull out. Painted then with Rustoleum paint.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
time2roll
Posted: 12/01/19 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
down home wrote:
The 2x12s will break on this soil. Work fine on hard surface though. The plastic orange ones will simply bend and sink,which won't help any. Found some made by dica. 18 inch 11/2 inch thick unbreakable, 70.00 each anywhere so far on the internet. Really don't want to spend that much but....
AND no this is not a commercial for them. No experience with them.
Can they be doubled up with second layer rotated 90 degrees? Tripled?
675w Solar pictures back up
 > jack pads
