RV.Net Open Roads Forum: Class C Motorhomes: toilet
 > toilet
pushtoy 2
texas
Posted: 11/30/19 10:06am Link  |  Quote  |  Print  |  Notify Moderator
does anyone how to fix the seal on the flusher.. the bowl wont hold water for more then an hour or so
DREAMER ">
IAMICHABOD
Sunny So Cal 90713
Posted: 11/30/19 10:15am Link  |  Quote  |  Print  |  Notify Moderator
Youtube is your friend
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
Dusty R
Charlotte Michigan 48813
Posted: 11/30/19 10:31am Link  |  Quote  |  Print  |  Notify Moderator
Try a few drops of vegetable/cooking oil in it.
Dusty
ItsyRV
Desert SW
Posted: 11/30/19 10:32am Link  |  Quote  |  Print  |  Notify Moderator
The seals are not that hard to replace. It varies by models so make sure you're looking at the directions for what yo have. Since you may have to remove the toilet from the floor, it's a good time to do all maintenance on the toilet. Think about replacing the floor seals, replace any "O" rings, inspect all parts and replace if worn and generally a thorough cleaning. I'm not a big fan on removing the toilet so when I do, everything is getting the once over.
If the current issue is just a very slow loss of water, you may be able to just rejuvenate the seal with one of those RV toilet seal conditioner liquids. They serve to condition and lubricate the seal and work pretty well on those slow leaks.
Good luck!
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
cavie
Posted: 11/30/19 10:47am Link  |  Quote  |  Print  |  Notify Moderator
domedic 310 can be a breeze or a real PITA.
2oldman
New Mexico
Posted: 11/30/19 10:52am Link  |  Quote  |  Print  |  Notify Moderator
Your domedic will hold for more then a our if you use vinegar.
ScottG
Bothell Wa.
Posted: 11/30/19 11:18am Link  |  Quote  |  Print  |  Notify Moderator
* This post was edited 11/30/19 07:40pm by ScottG *
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
ksg5000
Oregon
Posted: 11/30/19 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
You can try cleaning out the ravine or using oil ... but when that doesn't work then your going to have to remove the toilet and replace the defective mechanism. In hindsight some who have done this procedure might recommend replacing the toilet - there not that expensive and some of the newer toilets are much better than the old ones. In short - removing the toilet in some rigs is a PIA and if you have to go through the trouble why not replace it with something that is new?. Just my 02.
Kevin
pushtoy 2
texas
Posted: 11/30/19 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
thank you so much the video was perfect it show my exact toilet.. now iam not afraid to do it
IAMICHABOD
Sunny So Cal 90713
Posted: 11/30/19 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Thats great,[image]
There is a wealth of information here but sometimes you need to see how it is done.[emoticon]
Between the two I have fixed a lot of stuff.
 > toilet
