RV.Net Open Roads Forum: Travel Trailers: Installing rear wireless camera
 > Installing rear wireless camera
drsteve
Michigan
Posted: 12/01/19 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
freetime58 wrote:
drsteve wrote:
cougar28 wrote:
Also make sure your camera is a observation camera and not just a backup camera. Observation camera can be left on 24/7 and most backup camera will burn out if left on for extended time. A good friend of mine found that out after leaving his backup camera on while on the road after a couple hours.
Some of the cheaper backup cams have a delay in displaying the rear view, which makes them unsuitable as observation cams. The monitor might show nobody there, when in reality there is indeed a vehicle.
Furrion cameras and monitors are the same whether used as a back up camera or an observation camera.
Furrions are not one of the cheaper cameras...
1991 Palomino Filly PUP
Huntindog
Phoenix AZ
Posted: 12/02/19 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
My brother just did this on his camper.
He did not want to drill any holes.
So we hatched a plan to replace is center clearance light with the camera. He got a 1" thick peice of white cutting board (cheap on ebay) and made an adaptor. It attaches to the camper using the existing screw holes, and the camera attaches to the adaptor. A hole in the center is to run the clearance light wiring to the camera. It looks factory, and works great.
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2020 Silverado High Country CC DA 4X4 Big Dually.
