f150camper
Oregon
Hi all!
I am in the process of building a shop on my property.
The plan is to be able to park a travel trailer and/or coach in there.
Total shop size is 32(w)x48(d) with a 14x14 door.
My main question is this: How much room do I need in front of the shop to be able to get a travel trailer in there? Let's say a max travel trailer length of 35ft with a 20ft tow vehicle.
I have attached a quick drawing to visualize what I am talking about.
It looks like I will have about 57' (give or take a couple feet) in front of the shop. 44' of that will be on gravel, 13' will be on asphalt.
file:///C:/Users/kklein1/Desktop/temp/shop_space.jpg
Will this be enough room for a 35' TT or 40' Coach? I bet the Coach will be fine, but not sure about the TT.
BTW, I can't really try it out with the max length trailer, so please don't suggest that (placing cones, etc). We currently own a 21' TT, and I am sure I'll be fine getting that into the shop. I want to be able to use the shop down the road for things bigger than what we own now, or even enable any potential buyers.
Really appreciate any input!
last
edited 12/01/19 08:24am by f150camper *
View edit history
Nights camped 2011: 13 (4 in the old popup) ">
Nights camped 2012: 36
Nights camped 2013: 28
Nights camped 2014: 21
2012 F-150 XLT screw 4x4 HD max tow
2012 Jayco X19H
f150camper
Oregon
How in this world do I share images here? Used to work just fine, but have not done it in years.
Any help would be appreciated!
IAMICHABOD
Sunny So Cal 90713
Here You Go
Follow the Instructions Here
Pretty easy once you have done it.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
DrewE
Vermont
For the images, you're putting in the URL of a page with the image rather than a direct link to the image itself. This might work better.
![[image]](https://lh3.googleusercontent.com/NfS1UTCfg8lofxrBVOnF81cxAZ_ppPA8AqNshz_RAZvjkHWKXrsSzN2jDUPSlKXz_E3EugdjPiDXMNIJbkdkgmjwXHA9o1q8lJHh9mentUmtOZrA3LQcThoQ4AkX6GjbSlMCYD_YSw)
Here's my two cents, which may not be worth the pennies:
Maneuvering a trailer will partly depend on the tow vehicle: how tightly it can turn, and how sharp an angle you can get between it and the trailer without crunching something. With a good tow vehicle you could easily maneuver most any trailer into position with that space (well, you could provided you have some experience/skill at backing a trailer). One rather extreme example of a great vehicle for this is a standard farm tractor, which can turn very sharply if needed thanks to wheel brakes, pivoting around either of the back wheels.
A class A coach probably could be maneuvered into that space without extreme difficulty, I suspect, though I don't speak from any sort of personal experience. A large class C would probably be tricky as they tend to have pretty terrible minimum turning circles (and I do speak from some experience there). More room would definitely make things easier. I'm assuming the width of the gravel portion is at lest somewhat to scale--that it's considerably wider than the 13' wide asphalt drive, even if not nearly as wide as the shop.
You could back a semi trailer into that garage if the driveway is square to the road and as wide as the sketch.
There isn't a RV that can't be backed into the driveway or shop if it is as big as the sketch.
And a 48' long shop is a huge luxury. My shop is 36' long and I feel like I died and went to heaven with that big of shop!
(But I've got every bay filled in a 3 car garage and a 36x 36 ish shop and could use a couple more bays....)
midnightsadie
ohio
build the shop for you ,with a rv in there you lost your play room .put a side shed on the building for the rv, been there.
hondapro
Central Pa
You should have no problem backing a TT in there.You have plenty of space.
Steve
2016 F-350 6.7 Diesel
2015 Springdale 311RE
DutchmenSport
Indiana
It all depends upon your towing skills and how comfortable you are at backing up a trailer. If you are skilled at backing, I see no reason why the longer trailer would not fit.
navegator
San Diego CA.
If you are lookiing at the structure the door will be on the right, make the radius of the right corner where the ramp meets the road a bit wider and if posible always back the trailer or RV on a left turn, you will always see where you are going on your left mirror, and yes that is plenty of turning space.
navegator
dodge guy
Bartlett IL
For another $1200 you could get a powered trailer mover. But either way I think you will be fine with what you have suggested. I used to have a 35ft TT and a 20ft Excursion, 55ft total. And with a 14 ft wide door you can still back in on an angle and have the room to straighten it out. I wouldn't worry about it
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
