RV.Net Open Roads Forum: RV storage - how much room is needed?
 > RV storage - how much room is needed?
Page of 5
drsteve
Michigan
Posted: 12/01/19 07:25am Link  |  Quote  |  Print  |  Notify Moderator
Looks good from here--that's a lot of room to maneuver. You should have no problem at all.
1991 Palomino Filly PUP
jkwilson
Indiana
Posted: 12/01/19 07:56am Link  |  Quote  |  Print  |  Notify Moderator
You should be good for backing with the width of the road available to. If you need more space to get things straight, you may be able to put a culvert in the ditch across the road to allow you to pull forward further once you are in the driveway.
If you want to be able to put slides out inside the shed, you are going to eat up your space fast. You’ll have to park 4ft off the wall to clear the poles.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
f150camper
Oregon
Posted: 12/01/19 08:33am Link  |  Quote  |  Print  |  Notify Moderator
Thanks everybody!
Got the picture posted also, finally! Thanks for the link and instructions!
I am generally good backing up the trailer, have helped others in the campground on occasion. I just never backed it into a shop, and spending this much money, I want to be sure.
If I back it in doing a left turn, I will be pushing the trailer uphill, but that should be fine.
What do you guys think would be the longest trailer I could get in there without issues? Also, if I had a total of 50ft (instead of 57), would I still be fine? In that case, I would move the shop a few feet towards the road, giving me more space for firewood storage behind.
One more question: what's that powered trailer mover for $1,200?
Again, thanks a lot for all the help and feedback.
Nights camped 2011: 13 (4 in the old popup) ">
Nights camped 2012: 36
Nights camped 2013: 28
Nights camped 2014: 21
2012 F-150 XLT screw 4x4 HD max tow
2012 Jayco X19H
gbopp
The Keystone State
Posted: 12/01/19 08:55am Link  |  Quote  |  Print  |  Notify Moderator
Maybe a 16' wide door would help?
camp-n-family
London, Ontario
Posted: 12/01/19 08:59am Link  |  Quote  |  Print  |  Notify Moderator
If you have the room, I would build it far enough back so I could park on the driveway in front of the garage without infringing on the road while hooked up. Just a few reasons; Do you want to have to be all packed and hooked before pulling out? Do you want to worry about having to stop and block the road while going back to close the garage door when leaving? If you want to wash or work on the trailer in the drive you would have to unhook it.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
f150camper
Oregon
Posted: 12/01/19 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Thanks again!
I would only park the trailer in the shop during the winter (most likely), so once in, once out per year.
The shop will be on our property. When looking at the picture, the back of our house is about 120ft to the left or the shop. The private road in front of the shop wraps around and our driveway is attached to it. The road is used by us and 6 other houses only. In fact, the road itself is on our property, with a right-of-way for our neighbors.
We have a nice RV pad right next to the house also, where the trailer is parked now, and where we plan on having it parked during the summer and before / after trips for loading and unloading.
With the 44ft of gravel between the shop and the road, the rig (trailer + truck) would probably just fit there.
Lynnmor
Red Lion
Posted: 12/01/19 09:46am Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't waste the time and money if you are not going to use it as a garage. My opinion is that there in more damage to an RV during hot summer months than cold and darker winters. My trailer is indoors whenever it is not in use.
I put down marker tape on the floor for guidance when backing in so that the trailer is located where I want it. The idea of a larger door is good so that you can make the fine adjustments with little interference with traffic.
dodge guy
Bartlett IL
Posted: 12/01/19 09:49am Link  |  Quote  |  Print  |  Notify Moderator
I may have been off on my price a bit but here is one for $1400. Trailer mover
They go up from there. Looks like around $2200. They ca. Be had used for cheaper.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
navegator
San Diego CA.
Posted: 12/01/19 10:39am Link  |  Quote  |  Print  |  Notify Moderator
One item that helps backing into a dark hole on a sunny day is a yellow line going from inside the shop out a few feet in front of the doorway, having the shop lit is also a good idea, I have backed enoughh fire engines into dark holes to really apreciate that yellow line for some guidance.
navegator
f150camper
Oregon
Posted: 12/01/19 11:07am Link  |  Quote  |  Print  |  Notify Moderator
Thanks a lot to everybody, good input!
Lynnmor, we get a lot of snow here in the winter, I really would like to get the trailer away from that. Also, I'll see how quickly it will be to get it in and out. Maybe we'll always put it in the garage. Would be nice to have the extra parking by the house.
The shop is also not "just" for the TT, the trailer will take maybe 20% of the shop floor. Many more things to go in there - wood splitter, cargo trailer, 3 quads, mower, etc ....
Page of 5
