RV.Net Open Roads Forum: Ram box on short bed - ill-advised for towing a 5th wheel?
 > Ram box on short bed - ill-advised for towing a 5th wheel?
DesertDogs
Scottsdale
Posted: 11/30/19 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
I'm looking at Ram 3500 Mega Cabs with short beds for 5th wheel towing.
Does having Ram boxes on the sides of the truck bed present any kind of problem when it comes to towing a 5th wheel?
Considering Solitude 310GK 5th wheel
romore
Okanagan valley British Columbia
Posted: 11/30/19 10:43pm Link  |  Quote  |  Print  |  Notify Moderator
Take a close look at the front corners under the nose, if they are swept back you should not have any problems. Otherwise go with an automatic slider. I can't reach the pins on my manual with the trailer hooked up, the cab has a dent as evidence, so I have to be very careful.
DesertDogs
Scottsdale
Posted: 11/30/19 11:05pm Link  |  Quote  |  Print  |  Notify Moderator
I haven't bought truck nor 5th wheel yet. But looking at trucks and wondering if I should avoid getting a pickup with the Ram boxes, or if it really doesn't matter.
I'd be happy to go either way - but it the right truck comes along and it HAS Ram boxes, I want to know if I should pass on it and wait for another.
valhalla360
No paticular place.
Posted: 11/30/19 11:40pm Link  |  Quote  |  Print  |  Notify Moderator
Only issue I see is if the overhang clearance is too small and you wack the truck bed side...with the boxes open correctly? With a standard bed, you might have a dent but it's mostly cosmetic not functional issue...related, how much does it impact the repair price if the boxes are impacted?
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
MarkTwain
Northern, Ca. , USA
Posted: 12/01/19 12:58am Link  |  Quote  |  Print  |  Notify Moderator
Just curious, what is the advantage of a 6' bed VS an 8' bed. The 8' bed eliminates all the issues of the trailer hitting the cab of the truck.
thomas201
Eastern Panhandle WV
Posted: 12/01/19 05:36am Link  |  Quote  |  Print  |  Notify Moderator
Three quick ones:
Short beds meet the 22 foot rule in places like Toroweap/Tuweep. The 22 foot rule is just an extension of the shorter, the easier to turn around.
Short beds save money on ferry crossings without the camper, like Newfoundland.
Short beds give a slight edge with sliders in tight spots, even with a notched 5er. You move the pivot behind the wheels, kinda like a conventional trailer. Slider in an 8 foot bed does the same thing, but the front sticks out 2 more feet.
If I only towed, 8 footer all the way, but I dont't. I do medium 4 wheeling after I drop the tail, plus hunting, fishing, hauling wood, apples and so on. A compromise.
Darryl&Rita
Grande Prairie, Alberta
Posted: 12/01/19 05:49am Link  |  Quote  |  Print  |  Notify Moderator
Watch the length of the hitch on the trailer. Too long, it'll want to run into the inside of the truck bed in a turn.
***UPDATE 2006 3500 SRW MegaCab pulling a 2007 fleetwood 5'er
ACZL
UPstate,NY
Posted: 12/01/19 07:26am Link  |  Quote  |  Print  |  Notify Moderator
I think what OP is wondering about is opening up the RAM boxes on top of pick up box itself and not so much hitting back of cab. If I'm wrong, I apologize in advance.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
MarkTwain
Northern, Ca. , USA
Posted: 12/01/19 07:43am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the clarification. What are RAM boxes?
Learjet
Louisiana
Posted: 12/01/19 08:13am Link  |  Quote  |  Print  |  Notify Moderator
I see lots of people don't know what a Ram box is...it's the tool box built in the sides of the pickup bed which makes the inside of the pickup box narrow side to side.
The answers is yes, it is a problem with a 5th wheel...you'll need a Side winder pin box (or similar brand) on your trailer to have clearance inside the pickup box for turning....This would also give you clearance for tighter turns with the short pick bed and the cab. Two different issues "Ram box" and Short bed.
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2015 Wildcat 317RL, MoRryde rubber pin box, Titan Disc Brakes, Trojan T105
B&W Ram Companion
Yamaha EF2600c tri-fuel generator
Champion Model 46595- 3000/3500w
