RV.Net Open Roads Forum: Fifth-Wheels: Auto leveling airbag system??? How important is this?
 > Auto leveling airbag system??? How important is this?
DesertDogs
Scottsdale
Posted: 11/30/19 11:37pm Link  |  Quote  |  Print  |  Notify Moderator
Auto Leveling Airbag system???? I don't know enough about this feature - can you help?
This truck has more than enough towing & payload capacity for my 5th wheel needs, BUT... it does NOT have Auto Leveling Airbags. Should I pass on it for that reason?
Or - am I likely to do just fine WITHOUT auto leveling air bags?
Or - can I do just as well installing an aftermarket airbag system?
I can wait for another truck to come along that has factory airbags, if they are something that I am quite likely to want to have.
Lastly, will airbags make for a more comfortable ride when we are not towing?
Moderator edit to re-size images to forum recommended limit of 640px maximum width.
* This post was edited 12/02/19 01:59pm by an administrator/moderator *
Considering Solitude 310GK 5th wheel
valhalla360
No paticular place.
Posted: 12/01/19 06:13am Link  |  Quote  |  Print  |  Notify Moderator
At 15k GVWR, you are probably looking at 3000-3500lb pin weight...this truck is rated for 5300lb payload...should be fine even if you have some other cargo in the truck.
Airbags wouldn't be a bad thing but hardly necessary. Plus if you do want them, you can always do after market.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
dapperdan
Milwaukee
Posted: 12/01/19 07:20am Link  |  Quote  |  Print  |  Notify Moderator
I have the factory (rear) air suspension on our 2015 RAM. The air suspension "seeks" it's own level whatever the load is you put on the rear axel! I had Firestone air bags on our old '06 RAM just for leveling the ruck with the fiver on. Now the 2015 levels itself each and every time I add weight to the box. My truck ALWAYS sits level, load or NO load!
Our rear air has worked flawlessly since new! I love it!
Dan
Super_Dave
Harrisville, UT
Posted: 12/01/19 07:51am Link  |  Quote  |  Print  |  Notify Moderator
With the trucks sitting so high these days, I have virtually no air in my manual air bags to seek a level 5th wheel while towing. The air bags came in handy with my cabover camper but not needed at all for my 5th wheel.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
Cummins12V98
on the road
Posted: 12/01/19 08:33am Link  |  Quote  |  Print  |  Notify Moderator
I agree with dapper dan, I have the Factory Rear air Ride, it's a flawless system. Take my advice look for it or simply order the truck YOU want.
I run full RAWR of 9,750# or more and the truck rides GREAT and sets nearly level loaded or not.
I had bags on my 11 DRW RAM, they improved the loaded ride a lot. Unloaded the bags did not change the ride. My 15 with factory bags rides much better than the 11 did unloaded.
You are spending that much on a new truck $1,300 isn't going to make a big difference. If you decide to get a GOOD air bag system you will spend about the same. then from personal experience you will be dealing with air line leaks with any weather changes.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
DesertDogs
Scottsdale
Posted: 12/01/19 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
Apparently the ride is better, even with an unloaded truck, with the factory auto level air, because with that system, the leaf springs themselves are not as stiff.
Looks like that's the way to go. Thank you.
Cummins12V98
on the road
Posted: 12/01/19 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
Good call!
Slownsy
Posted: 12/01/19 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
Something has to carry the truck whether air or steel springs, I added air bags to a older truck 2006 and it did make it stiffer in the rear with only the minimum 10lb pressure in them.
Frank
Frank
2012 F250 XLT
4x4 Super Cab
8' Tray 6.2lt, 3.7 Diff.
Cummins12V98
on the road
Posted: 12/01/19 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
PacBrake bags required 5psi empty. Did not notice and difference. Personally never heard of 10 psi min.
Super_Dave
Harrisville, UT
Posted: 12/02/19 08:13am Link  |  Quote  |  Print  |  Notify Moderator
As a side note, that is an absolutely gorgeous truck!!
