RV.Net Open Roads Forum: Tech Issues: Converter kaput need to buy better one.
 > Converter kaput need to buy better one.
agesilaus
North Florida
Posted: 12/01/19 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
I'm fairly sure my converter is kaput. It will not charge my 6VX2 Batteries and I want to go to two banks of 6V batteries. I did work for our summer 7 week trip.
So how do you size a new converter. We have a 30amp system and want to do much more boondocking. Also I have 400W of solar panels not yet connected with a Victron controller.
Any brand recommendations? I think the current one is a Progressive.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
enblethen
Moses Lake, WA
Posted: 12/01/19 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
What is the amperage of your existing converter? What size wire goes from the converter to the batteries?
A 45 amp would normally suffice! With larger wire you could go up.
PD 9245 would be my choice.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
BFL13
Victoria, BC
Posted: 12/01/19 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
The RV's 30a has nothing to do with the converter size.
The converter size in amps is related to the power output of your generator, measured in VA. A typical converter has 0.7 power factor.
If your generator can run 1600w (VA) as its rating, then your input to the converter can be 1120 watts. Typical converter efficiency is 85% so output would be 952 watts. Output is in DC and you want 14.8v for those 6s, so 952/14.8= 64.3 amps. So you can have a 60 amp converter, but not a 75 amper unless you have more of a generator.
I like the adjustable voltage you get with the PowerMax LK models so you can also crank it to 16.2v for equalizing the 6s every so often as , eg Trojan recommends. Nobody else makes a converter like that, and check out the price!
https://www.boatandrvaccessories.com/pro........er-converter-battery-charger-w-led-light
You can do all four 6s at once with a 100 amp LK, but you need more like a "3000w" generator to run it. Maybe a 2500.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
enblethen
Moses Lake, WA
Posted: 12/01/19 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
I should have asked for model of your converter and verify the make.
agesilaus
North Florida
Posted: 12/01/19 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
I'll get the make and model in the morning. I think the nameplate is on the back side of course. But I just bought a boroscope that should help there.
My generator is a Champion 3500/4000 that we only had to run once last summer on a hot afternoon in ND. But we only stayed 2 or 3 days in one spot, we will be doing long stays next summer when we go semi-fulltime.
IAMICHABOD
Sunny So Cal 90713
Posted: 12/01/19 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
If you are looking at these I will suggest that you look at their new
9200 series Modified Deck Mount
These converter/chargers will deliver 14.8 volts during the boost phase of charging,much better for Trojan and others requiring a higher (14.8 VDC) boost or bulk voltage.
* This post was edited 12/02/19 03:32pm by IAMICHABOD *
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
BFL13
Victoria, BC
Posted: 12/01/19 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
You have enough generator to run a 100 amp or even higher amp charger.
A. What do you mean by "two banks"? Is this just the usual 4 sixes in series/parallel you can charge all at once, or some other set- up that you can only do two at a time? If so, why?
B. If getting ready to do more off-grid, why not an inverter-charger? They come with up to 150 amp chargers in them, 120 amp is common. You can do that.
C. Many prefer separate charger and inverter (me too),so you can still get a 2000w inverter and a 100 or 120a charger. (Again I like the PowerMax versions of all those, but there are other choices.)
BTW, nobody questioned whether your converter is indeed toast. Are you sure, or should we get into whether it is toast or not?
* This post was edited 12/01/19 07:03pm by BFL13 *
agesilaus
North Florida
Posted: 12/01/19 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
A. Yes 2 X 6V in two parallel banks
B. I have a 1500W inverter not installed yet to go with the rest of the solar setup I have. Maybe I should look at an inverter charger tho.
BTW--I'll double check it in the morning I have a troubleshooting sheet.
BFL13
Victoria, BC
Posted: 12/01/19 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
Ok, so whatever you find out, we have lots of ways to spend your money! Having that big gen gives you many options.
If the sun is shining while you do your gen recharge and you can set your charger volts to equal your solar controller volts, they will add their amps for an even faster recharge. It is handy if they are adjustable voltage so they can match their voltages.
Wherever I happen to park
Posted: 12/02/19 05:54am Link  |  Quote  |  Print  |  Notify Moderator
Best converters for common Lead Acid (GC-2 six volt pairs) batteries in my not very humble opinion is the Progressive Dynamics "Charge Wizard" controlled units
Stand along model lines 9200 with or without dongle (dongle is useful if you know how to use it) or 9100 WITH the charge wizard (What I have)
"Integrated" (Part of Power distribution panel) 4600 (electronically same as 9200 but different case)
Note even these will fail Eventually Mine lasted 12.5 years.
How big? for one pair of GC-2 60-70 amps (mine is 80) for 2 (or more) the biggest they make (80).> HOWEVER you may need to put in bigger wire for a bigger converter.
Option: I also have a Inverter/charger (2000 watt xantrex) and they do 80-100 amps (mine is 80 max my old one was 100) they too fail after years of service.
I have days when (Due to where they put the 9180) I use both. I prefer the Wizard's program to the Xantrex
Home is where I park it.
