RV.Net Open Roads Forum: Tech Issues: Converter kaput need to buy better one.
 > Converter kaput need to buy better one.
LittleBill
Scranton, PA USA
Posted: 12/02/19 06:08am Link  |  Quote  |  Print  |  Notify Moderator
you can get the pd 60 amp version as well, sometimes these fit better then the 945 since they are slimmer
pd9260
time2roll
Posted: 12/02/19 08:51am Link  |  Quote  |  Print  |  Notify Moderator
45 to 60 amps is fine. I would replace with same rating.
PD92xx or PD92xx-14.8
675w Solar pictures back up
enblethen
Moses Lake, WA
Posted: 12/02/19 09:04am Link  |  Quote  |  Print  |  Notify Moderator
OP:
Haven't seen a reply as to what converter you now have. I suggested the PD9245, but if you have a converter that is mounted below the breakers and fuse panel, I would have to rethink replacement.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
ScottG
Bothell Wa.
Posted: 12/02/19 10:33am Link  |  Quote  |  Print  |  Notify Moderator
Another vote for the 60A PDI with Charge Wizzard.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
agesilaus
North Florida
Posted: 12/02/19 11:03am Link  |  Quote  |  Print  |  Notify Moderator
OK just an interim report: It is an Progressive Dynamics Intell-Power, 9200 I assume. Not sure yet what model it is, I'll have to unbox the boroscope I just got and figure out how to work it with my phone. It has 3 X 25 AMP fuses, all good.
Looks like this
Thanks to everyone for all the posts.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
DrewE
Vermont
Posted: 12/02/19 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
I'd double-check the connections before assuming it's bad. If it is malfunctioning, giving Progresive Dynamics a call in regards to repair/service might be a fruitful exercise; they have better than average support, from what I understand.
One rather obvious thing to check is to make sure the outlet it's plugged into is receiving 120V power.
enblethen
Moses Lake, WA
Posted: 12/02/19 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
I would test the fuses, do not go by looks.
PD 9200 series is still my choice.
