RV.Net Open Roads Forum: What jack to have onboard for roadside tire changes?
 > What jack to have onboard for roadside tire changes?
Son of Norway
Denver, Colorado
Posted: 12/01/19 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
I have managed to travel in my HR for 10 years without ever having a flat or blow-out on the road. I have always carried a 6-ton bottle jack thinking that I would use that and boards as needed if the situation ever occurred.
Today I watched a you-tube video on a blow-out incident and I am embarrassed to admit that I now realize a bottle jack will never work when a front rim with a shredded tire has dug itself down into the shoulder of the road. I suppose what I really should be taking might be a low-profile floor jack?
What do you recommend as the best type of jack to carry for roadside tire changes?
Thanks for your advice.
Miles and Darcey
1989 Holiday Rambler Crown Imperial
Denver, CO
Johno02
Lexington, TN USA
Posted: 12/01/19 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
Actually, if you have a leveling system on your coach, use that. I normally do not recommend ever raising the real wheels off the ground, but I do know that it can be done. during the one rear tire blowout we have had, I called my emergence road service to come change it for me. I asked the service person "my jacks or yours", we used mine, then he put a jackstand under the axle for safety, and we lowered onto it. With a dual axle, I don't know. He said that he actually felt better about my jacks than his!
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and a grouchy, old, tiny dog
Dutch_12078
Winters south, summers north
Posted: 12/01/19 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
Does your HR have hydraulic levelers? I've used them to raise an axle high enough to get a 20-ton bottle jack under it on occasion.
Dutch
2001 GBM Landau 34' Class A
rk911
Wheaton IL
Posted: 12/01/19 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
a working, charged cellphone, a roadside service plan and a credit card.
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
All I could afford
North jersey
Posted: 12/01/19 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
You could also drive the flat tire up onto a 2x6 board or two in order to lift the axle a bit before setting up the jack
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollin’ on 33’s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
DFord
Near St Louis, MO
Posted: 12/01/19 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
I had a flat several years ago on the inner dual - before I learned RV tires age out after 7 years.
My MH didn't have levelers.
I called my road service and about 2 hours later Homer and Jethro showed with in a broken down El Camino with their huge floorjack and crossbar wrench. Unfortunately, after they pushed it under my MH, the restricted movement on the handle didn't allow the pump to function so they couldn't use it. I offered my bottle jack which they were able to get under the axle and raise the tire off the ground. They were able to swap tires but as they were tightening the lugs, they put enough torque on the lugnuts to turn the tire causing the tire on the opposite side to turn the other way and the HM came down hard off the jack. They (and I) had forgotten to chock the tires! Lesson learned and disaster was avoided.
If you blow a tire and the wheel digs into the ground, I doubt if you'll be to get anything to raise the wheel at that location because anything you use will just push itself into the ground while trying to push up on the axle. Best to call your roadside assistance provider and let them handle it - hoping Homer and Jethro aren't the ones they send.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
Los Angeles area :(
Posted: 12/01/19 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
Do you believe that you alone could change a tire of that size?
Son of Norway
Denver, Colorado
Posted: 12/01/19 10:35pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the help. The HR does have levelers, and I always have the cellphone, road service and credit card. I guess I'll just keep the bottle jack and hope that things work out if the time ever comes!
rgatijnet1
Posted: 12/02/19 04:08am Link  |  Quote  |  Print  |  Notify Moderator
I have used the rear leveler, with boards under it, to raise ONE side of the rear axle enough to change a tire. I set the brakes and blocked the front axle so the coach would not roll. Naturally after I had raised the rear axle I put a jack stand under the axle for safety. For the front axle, it is really easy to use the levelers to raise the front axle, insert a jack stand, and do what you need to do.
Airdaile
On The Road
Posted: 12/02/19 04:57am Link  |  Quote  |  Print  |  Notify Moderator
Bottle jack here.
