RV.Net Open Roads Forum: Fifth-Wheels: Bent Kingpin?
 > Bent Kingpin?
bucky
Raleigh metro
Posted: 12/08/19 03:31am Link  |  Quote  |  Print  |  Notify Moderator
So it's a week later OP. What did you/they find was the problem?
2005 Cummins 2500 2WD LB quad cab pulling a 2014 Blue Ridge 3025RL
jodeb720
Los Angeles
Posted: 12/10/19 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry Guys - OP here.
The trailer is in Santa Fe, NM and I'm in Denver - so I have to plan a road trip down to the storage facility to review what's going on with the pinbox (and thank you for clarification on the correct terminology).
There's been some questions.
1. No, I didn't adjust the connection between the Kingpin (Spindle) and the Pinbox -
2. I've not had a chance to drive down (it's 400 miles) and peel back the plastic (under side around the front compartment and the nose above to get a look at it.
3. Under my bed is all covered in "quality" carpet. But it's a good idea to remove all the wood above the area if they are going to be welding.
4. I reached out to my bro in law who works for an insurance company. Had the nose crashed into the bed and bent it, the bed of the truck, and the trailer would have been covered - since the trailer is considered to be part of the truck - not a separate rider on the insurance polcy - and before someone recommends letting it - It's just not who I am. For someone else, that's an option but it's just my karma.
Depending on the weather (it's not supposed to snow here, but the weather is reporting 5" of snow between here and Santa Fe - but not in Santa Fe - so we'll see how the road trip goes.
My guess is that it will be another week before i go down to peel it all back and assess the damage.
Next will be looking for a quality welder in the greater Santa Fe area.
My alternatives are limited - I could tow it to denver - but how would I get it on a trailer? I don't have enough clearance to back it in. I guess a forklift could do it.
Again, thanks to all of you for your suggestions. It's this place that has helped me over the years and the community has made these types of problems, manageable!
Josh
DesertDogs
Scottsdale
Posted: 12/11/19 10:39pm Link  |  Quote  |  Print  |  Notify Moderator
Please keep us posted.
Considering Solitude 310GK 5th wheel
reluyog
Colorado
Posted: 12/17/19 11:33am Link  |  Quote  |  Print  |  Notify Moderator
A couple of years ago I noticed our pin box had been moving forward and back just a little by looking at the fiberglass joint just forward of the pin box area. None of the supporting structure actually bent permanently, but it had been flexing enough to identify a problem. Ultimately I cut out the fiberglass overhang at the front corners, roughly 4' x 4' with a 4" cut off wheel. I added about 250 lbs of 1/4" thick angle iron, and constructed some gussets for the corners where the pin box receiver is located. I decided to bolt everything in with grade 8 instead of welding. I had been carrying too much weight (tools) in the front area of the 5th wheel which caused the issue, plus double towing from time to time.
So if you have your trailer frame re-welded, I would suggest you add to that with some extra steel to strengthen the entire structure.
When I reinstalled the fiberglass panels, I made "L" brackets that allowed me to have threaded holes to attach the panels. Then I used stainless screws and covered the seams with 2" x 1/8" thick aluminum strapping. I also added new insulation and used the aluminum strapping to create a tight (read mouse proof) seal around the pin box.
We have an older Carriage triple axle, and also from Denver. We use a storage facility in the Southern part of Denver metro.
Good luck
Damian
1983 KW W900, 3406B Cat, RTO15, 355's
1995 Carriage by Carriage triple axle 22K
moe f
ON.
Posted: 01/14/20 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
Been anxiously awaiting an update. Is there one ?
laknox
Arizona
Posted: 01/15/20 08:53am Link  |  Quote  |  Print  |  Notify Moderator
Go back 3 posts earlier than yours...
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
philh
Belleville MI
Posted: 01/15/20 10:01am Link  |  Quote  |  Print  |  Notify Moderator
OP and anyone else experiencing these failures should be filing complaints with NTSB. It's a road safety hazard and does pay attention to a developing pattern, and could issue a recall.
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 01/16/20 08:39am Link  |  Quote  |  Print  |  Notify Moderator
Like many others he will find broken beams and structure, and some welds that let go. From OP profile trailer is 2010 Keystone Cougar 244RLS(I now see that he had that in his original post), so I would be surprised if Lippert helps him. 10 year old trailer looking at 4-5K repair. And it is 400 away, and he is paying storage. Not good! Chris
* This post was edited 01/16/20 09:10am by Me Again *
aboatrguy
home
Posted: 02/05/20 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
DOT / NHTSA can be contacted at (888)327-4236 reference #11267716 and tell them you also have a similar failure with an LCI frame. Add your failure to the list and we can get results from an investigation.
My 27' toy hauler has I beam crack 9' on both sides, which allowed the axles to move around under trailer while traveling thru the mountains with my family. The CHP said they woul have been picking us up in pieces if we had continued to the next set of turns. I had LCI and Eclipse RV Manufacturing pay the bill to weld up and get us on the road home, but the next time we went to use it, the A-frame broke apart and was ready to completely fail, which would have been catastrophic. LCI sent an employee in an LCI truck to my business to weld that up too. This caused a lot of other damages to the trailer that they both said they would take care of after they got a dealer estimate, but nothing but crickets since!!!
They need to be taken down to the woodshed and taught a lesson, so lets get as many people to get on board with this to make things right!
 > Bent Kingpin?
