RV.Net Open Roads Forum: Furnace blower stops briefly then comes back on.
 > Furnace blower stops briefly then comes back on.
RoyF
Fayetteville Arkansas
Posted: 12/02/19 08:13am Link  |  Quote  |  Print  |  Notify Moderator
Atwood Furnace in 2008 fifth wheel: Blower motor stops for two or three seconds then starts again. I don't think that the furnace flames out (I don't hear a 'click'), but I'm not 100% on that. This happens every few minutes. My worry is that the blower will stop and not start again.
Old-Biscuit
Verde Valley
Posted: 12/02/19 08:16am Link  |  Quote  |  Print  |  Notify Moderator
Furance Fan Motor is failing......or bad ground wire on motor
bid_time
Michigan
Posted: 12/02/19 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Don't know about RV furnaces, but some furnaces have a limit switch where the heat exchanger has to be up to a certain temp or the fan stops until temp comes back up. If for instance you were just turning the furnace on in a real cold house, the fan would stop momentarily every time that real cold are on the intake side lowered the heat exchanger temperature to much; until the heat exchanger came back up to operating temp, then the fan would kick back on. So if your RV furnace has the same type of operation, this could be normal. If however the house ain't that cold, could be some other problem.
larry cad
ohio
Posted: 12/02/19 11:37am Link  |  Quote  |  Print  |  Notify Moderator
I am more inclined to think the flame goes on and off, rather than the blower. If the blower isn't running, the flame cannot come on due to the sail switch not made. Might want to listen closer to the various noises.
Our Travel Blog
doxiemom11
Paris Michigan
Posted: 12/02/19 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
Our Atwood has a high temperature switch that will temporarily shut down the burner to let it cool. The fan continues to blow warm air and then the burner relights until such time as the temperature has reached what you set the thermostat for.
starcraft69
northern California(State Of Jefferson)
Posted: 12/02/19 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
+1 this is it
2007 chevy 2500 HD 6.0 longbed
2015 Eagle HT 28.5 5th wheel
tucker the fishing dog
West & above Bishop, California
Posted: 12/02/19 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
I agree. Fan motor failing.
