RV.Net Open Roads Forum: Renogy 100ah LifePo4 Lithium - Max Surge Current
 > Renogy 100ah LifePo4 Lithium - Max Surge Current
otrfun
On The Road
Posted: 12/02/19 10:00am Link  |  Quote  |  Print  |  Notify Moderator
Renogy tech support is telling me the BMS on their standard (not Smart) 100ah LifePo4 battery will shut down the battery if the current exceeds 100a, period---that it has no surge capability like the Battle Born and Lifeblue lithium batteries. The BB and LB batteries can surge up to 200a - 300a for very short periods.
Anyone using (or has used) the Renogy 100ah LifePo4 that can offer some realworld feedback on its surge capability? Thanks!
2oldman
New Mexico
Posted: 12/02/19 10:48am Link  |  Quote  |  Print  |  Notify Moderator
I'm using 100ah 48v pack and it surges just fine. It's hard to imagine subjecting a single 12v battery to 100a draw.
It also has to be a known fact those other batteries actually *will* do that.
* This post was edited 12/02/19 10:58am by 2oldman *
time2roll
Posted: 12/02/19 11:03am Link  |  Quote  |  Print  |  Notify Moderator
So get a second battery already. (or a third for that matter)
What do you have drawing all those amps?
675w Solar pictures back up
MDKMDK
Canada
Posted: 12/02/19 11:47am Link  |  Quote  |  Print  |  Notify Moderator
Mechanical devices may have short duration high amp draws.
Generator or engine starter motors, are 2 examples that may or may not invoke the excessive discharge/shut down programming of the internal BMS. I have 2 Relion 100Ah low temp 12V batteries in parallel, and they have exhibited intermittent tendencies to shut down during generator starts. Usually, if I depress the gen prep button and hold it for 30 seconds before hitting the start button, it will fire up without issue. Starting the generator with chassis engine running also works/helps. I haven't tried the battery boost switch to start the chassis engine with help from the lithiums yet.
I'm also guessing that SoC of the battery(ies) will affect the decision making process for when the BMS will invoke the high draw shutdown.
It might be the only down side (besides price?) of lithium batteries. I am aware that some of the manufacturers also offer models that are less susceptible to this issue. Relion does, but I wanted the cold weather charging models.
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
otrfun
On The Road
Posted: 12/02/19 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
Assuming the Battle Born and LifeBlue 100ah batteries can perform to their own specs, I'd say yes, they will. Both are rated at 100a continuous. The BB can surge to 200a for 30 sec. The LB, 300a for 3 sec. So, the question remains, how long can they produce, say, 110a before the BMS shuts the battery down (due to excessive heat or discharge). How long at 120a? How long at 130a? etc.
For those with space/weight/cost concerns, and high current needs, this would be nice data to have.
Itinerant1
Itinerant
Posted: 12/02/19 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
LFP batteries are good, maybe you're expecting more than what 1 100ah battery can perform. What exactly are you using over 100a on a 100ah battery?
otrfun
On The Road
Posted: 12/02/19 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
We're trying to power some portable test equipment. Only have weight/space available for one group 31 sized LifePo4 battery. FWIW, the same scenario could be applicable to someone with, say, a truck camper (with very limited battery space) who wanted to run a very small microwave.
In any case, just spoke to a LifeBlue distributor who does solar installs. I asked him about the LifeBlue LifePo4 100ah battery's performance when discharged/loaded slightly above its rated continuous capacity. He seemed intriqued with the question, so he's offered to test a fully-charged Lifeblue 100ah (with a 100a continuous rating) at 110-120a sometime this week. It'll be interesting to hear the results.
Edit: Wow, the distributor just emailed me his test results! Apparently the LifeBlue LifePo4 100ah battery's BMS shuts down the battery with a 110a load after 30 seconds. He did the test several times. It would appear the Renogy and LifeBlue BMS's, both, operate similarly.
Disappointing. On to plan B.
* This post was edited 12/02/19 02:57pm by otrfun *
Itinerant1
Itinerant
Posted: 12/02/19 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
Here is the specs for the Relion RB100
The discharge shows peak 200a. One thing I'll say about Relion battery site it is hard to find info without a lot of fishing.
Incase that is small here is a shot of the discharge specs.
MDKMDK
Canada
Posted: 12/02/19 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
They also have a slightly more expensive (what's a few hundred bucks to get what you need?) model, the RB100 HP with an 800A peak discharge rating and a 1000A discharge cutoff. More in line with the cranking amps ratings of an FLA chassis/starting battery.
DISCHARGE SPECIFICATIONS
Maximum Continuous Discharge Current 100 A
Peak Discharge Current 800 A (2 s)
BMS Discharge Current Cut-Off 1000 A ±100 A (2.2 ±1 ms)
Recommended Low Voltage Disconnect 11 V
BMS Discharge Voltage Cut-Off 9.2 V (2.3 ±0.08 vpc) (4.2 ±0.5 s)
Reconnect Voltage 10 V (2.5 ±0.1 vpc)
Short Circuit Protection 200-600 µs
Just depends on your needs. They've got something for everyone there.
The RB100 has a little bit of a cushion that might keep the BMS from shutting off the discharge circuit at almost 330A, if I read the + or - thing correctly.
time2roll
Posted: 12/02/19 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
I don't think a microwave has much surge at the start. s/b easy to stay under 100 amps. Only real surge in an RV would be an air conditioner and that is not really a concern if you are limited to one battery.
