RV.Net Open Roads Forum: Class A Motorhomes: 15 Amp Service
 > 15 Amp Service
haste maker
alabama
Posted: 12/02/19 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
We are going to visit family this Christmas & will be parking in their yard & they said we can plug into their house system...but it is only 15 amp...what do we need to NOT turn on with this low amp service?
Retried Teamster
2007 Allergo
agwill
enosburg falls, vt
Posted: 12/02/19 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
Run water heater and refrigerator on gas and you are good to go power wise. Fill up onboard water and do not hook up water hose. Pink RV antifreeze in tanks. If using just for sleeping no water needed use plastic bag in toilet bowl for number 2. Gallon water jug instead of water tank.
al
Mono Basin National Forest Scenic Area
Posted: 12/02/19 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
You can live very well in an RV with 15 amp plugin.
larry cad
ohio
Posted: 12/02/19 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
That will keep your batteries charged and that's about it. You can run your furnace, but no electric heaters. Also don't heat water with electric. You will find out real quick if you overload the circuit and the house breaker trips.
Our Travel Blog
Johno02
Lexington, TN USA
Posted: 12/02/19 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
What part of the Country are you going to?? Just remember that a 15 Amp circuit is the same as the wall outlets in one room of your house. If you are staying south, use normal winterizing, but do not try to use an electric heater to heat the rig. NoACs, hair dryers, very limited microwave, no electric heaters, fridge and Water heater on gas, and remember that converter that provides 12V stuff and battery charging pull pretty heavy also.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and a grouchy, old, tiny dog
wildtoad
Blythewood, SC
Posted: 12/02/19 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
Agree run water heater, fridge, furnace on propane only. Try not to use microwave, coffee makers at the same time. How you use water is up to you. If family is in the south then use it as you normally do.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Ed_Gee
Central Oregon coast
Posted: 12/02/19 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
You can get by on 15A if you adhere to what others have suggested.....but you may want to take a look at their house breaker for the garage wall outlets. Often garages are wired for 20A.....it can make a difference. Also suggest using 12gage extension cord instead of lesser 14 or worse 16 gage cord.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
DownTheAvenue
Sunny South
Posted: 12/02/19 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
This is just an issue of assumption conservation. You can run one heavy consumer of electricity at a time. The microwave with everything else off. A space heater with everything else turned off. I have done this for years at my brother's house. I use a 10 gauge extension cord and run the converter to keep the batteries charged and run a space heater constantly with it set to a 750 watt setting. I watch TV, make coffee in the morning, and keep the batteries charged without issue. I heat water on propane and keep the refrigerator on gas. Never a problem.
midnightsadie
ohio
Posted: 12/02/19 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
it would be nice to check the house see what else is on that same 15amp breaker . if nothing use as others have said .
2oldman
New Mexico
Posted: 12/02/19 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
Ugh..and where does this bag end up? Use water or go in the house.
 > 15 Amp Service
