RV.Net Open Roads Forum: You may have shocks but are they mounted right.
 > You may have shocks but are they mounted right.
ivbinconned
highway 16
Posted: 12/03/19 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
Mine were not.
08 Cedar Creek. 34 foot.
With new springs under it the original shocks had only 1/2 to 3/4 inch of compression travel left! This with no fluids on board.
There is a total of 4 inches of travel and Monroe says we should have at least 60 % compression available for impact. And the more vertical the mount the more you utilize the shock.
My shocks are mounted at about 45 degrees. Of course the closer to horizontal they become ...they would be even more useless.
Mine had been acting as a limiting factor bottoming out when the wheel goes up and driving the metal washer over the nut on the shock tube.
Effectively providing no shock absorbing at all.
The shock then and it’s mounts lifting the trailer on an impact....instead of the springs.
Nuts.
Where is quality control?
Ram and 34 ft Cedar Creek
momentum rv
Central Cal.
Posted: 12/03/19 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
I have seen many out there mounted nearly horizontal. Totally useless.
2015 Grand Design Momentum 385TH
2015 Ford F-350 DRW 4x4 Lariat
Yosemite Sam1
Under the pines.
Posted: 12/03/19 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
Who is idiot clown who installed it?
Lived without it for years. This post may discourage me to have those installed in my new unit.
Chris Bryant
Arden, North Carolina
Posted: 12/03/19 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
I’ll point out that there are shocks meant to be installed horizontally, though tases obviously are not, but the lack of travel is inexcusable- it should never bottom out on the shock.
-- Chris Bryant
Second Chance
Wherever...
Posted: 12/03/19 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
This is how my shocks are mounted (a little hard to see, but that's the shock behind the suspension link).
[image]Click For Full-Size Image.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
fj12ryder
Platte City, MO
Posted: 12/03/19 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, horizontal shocks will work if they're designed for the position, and there is the correct linkage. Many motorcycle shocks are mounted horizontally, with the corresponding linkage to work correctly.
Howard and Peggy
"Don't Panic"
Yosemite Sam1
Under the pines.
Posted: 12/03/19 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
Bicycle shocks are horizontal.
But without a play, it's basically useless.
fj12ryder
Platte City, MO
Posted: 12/03/19 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
"But without a play, it's basically useless."
Whaaaaa?
ivbinconned
highway 16
Posted: 12/03/19 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
Second , that looks like a whole new suspension. And the right kind too.
Retired JSO
Northeast Florida
Posted: 12/03/19 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
Torsion axles don’t really need shocks and shocks are not ment to bottom out. That’s why our trucks have bump stops front and rear.
