RV.Net Open Roads Forum: Towing: Charging trailer battery while towing and smart charging
Search only in Towing
Open Roads Forum  >  Towing
 > Charging trailer battery while towing and smart charging
pianotuna
Regina, SK, Canada
Posted: 12/05/19 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
opnspaces wrote:
Yes I do get that a DC to DC converter should do what I need. But those seem to be hundreds of dollars.
Thanks
Here is one that does up to 15 amps for about $30 bucks.
https://www.amazon.com/Numerical-Regulat........nverter+adjustable&qid=1575607837&sr=8-3
Regards, Don
ivbinconned
highway 16
Posted: 12/15/19 09:16am Link  |  Quote  |  Print  |  Notify Moderator
You are pulling with a Suburban so what I do is not an option for you how ever I will describe what I do for the benefit of all.
I use a “20amp Smart Charger around the farm year round and we have a 2000 Yamaha gen/inverter.
I fished an extension cord from the 4 - 6 volt batteries to the fifth wheel hitch. I set the gen on eco in The back of the truck, plugin the charger and clamp to the batteries.
If we use the furnace all night while boon docking on the road the house batteries get charged properly as we cruse down the highway.
A heavy gaged wire from your truck battery to trailer batteries may take out your alternator.
Ram and 34 ft Cedar Creek
rvshrinker
Beautiful Pacific Northwest
Posted: 12/20/19 11:44pm Link  |  Quote  |  Print  |  Notify Moderator
Second Chance wrote:
corvettekent wrote:
About 200 watts of solar on the roof of your trailer will keep your batteries charged when traveling down the road.
This^^.
Rob
Everywhere? Are you sure?
Today my 40 panel 12 kWp HOME solar system generated a grand total of 3.47 kWh. It’s like that a lot in this part of the country, this time of year.
2112
Posted: 12/21/19 02:02am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Thanks
This is the one I use
https://www.amazon.com/Voltage-Converter........918618&sprefix=Drok%2Caps%2C1001&sr=8-19
2013 KZ Durango 2857
sayoung
Tx
Posted: 12/21/19 06:12am Link  |  Quote  |  Print  |  Notify Moderator
I added a 2nd 50amp plug at the front of our 5er along with a transfer switch/surge protection . I just use this to run the AC when we have our pooches with us & need to stop for a while. We don't boondock so was never concerned about high current charging wile traveling
