RV.Net Open Roads Forum: Class A Motorhomes: Continental Tires PSI rising 20
 > Continental Tires PSI rising 20
MountainAir05
New Mexico
Posted: 12/07/19 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
rgatijnet1 wrote:
Sometimes when a tire is mounted by a rookie, he will use an excessive amount of lubricant to get the tire in place. All of that excess lubricant/moisture may be in your tire and causing your temps to increase a little higher than normal, since you did not have that issue with your other tires.
I am reading pressure went up not temp.
K Charles
Connecticut
Posted: 12/07/19 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
The OP said "20 degree rise of the psi" so is that degrees or pressure?
rgatijnet1
Posted: 12/07/19 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
Tire pressure usually goes up when the temperature goes up.
Octaneforce
Long island
Posted: 12/07/19 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
Do you notice any vibrations? Maybe these tires aren’t balanced as well and causing more heat.
1993 fleetwood coronado 30’ class a chuggin along with a tbi 454
An On demand hot water heater was the best thing i ever did
SGTJOE
Utah
Posted: 12/07/19 11:02pm Link  |  Quote  |  Print  |  Notify Moderator
There has been no vibration.
2001 Trade Winds 7390
Toad 03 Grand Am
CapriRacer
Somewhere in the US
Posted: 12/08/19 07:09am Link  |  Quote  |  Print  |  Notify Moderator
Second vote that the data points don't match: If the pressure goes up, so should the temperature.
While I like the idea of reinflating the tires with known dry air (or nitrogen), I'll bet that makes no difference - which would prove my contention that even with known water in a tire, it hardly affects the pressure buildup at all.
CapriRacer
Visit my web site: www.BarrysTireTech.com
wolfe10
Posted: 12/08/19 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
Let's restate that:
Pressure WILL go up as temperature rises. Well proven in the 1800's. Still true today.
PV=nRT
https://en.wikipedia.org/wiki/Ideal_gas_law
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Chum lee
Albuquerque, NM
Posted: 12/09/19 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
There are some well known "leak sealants/lubricants" which use relatively low boiling point hydrocarbons that can cause excessive pressure rise. Did the shop that installed the new tires by chance . . . . . install . . . . anything else, other than the new tires? IMO, a sniff test for contaminates inside the tires is in order.
Chum lee
Monterey, CA
Posted: 12/11/19 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
“before TPMS you never knew or even thought about how much they increased.“
I love new things to worry about! (Not)
