RV.Net Open Roads Forum: General RVing Issues: Good thing bad thing
 > Good thing bad thing
Lynnmor
Red Lion
Posted: 12/13/19 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
rvshrinker wrote:
What does exhaust mode mean? My fan has an on-off switch only.
How would air get sucked from the black tank to the toilet? There s no suction created; at least in my bathroom there is a gap at the top and bottom of the door to prevent moisture buildup.
This doesn’t make any sense to me.
If air is blowing out of the trailer, it must come in somewhere. Open a window or open the toilet, your choice.
rvshrinker
Beautiful Pacific Northwest
Posted: 12/13/19 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
Is this a well documented real hazard? I mean, air goes out the kitchen vent whenever it is turned on; and presumably some air can come in as well. A hint of air can come in from around the doors, and maybe from around the slide seals.
I don’t see a lot about this on google, and we’ve run the vent plenty without opening any windows.
You’re saying if I get a hint of eau de toilette I’ve somehow overcome the valve described above? Or the water trap itself?
opnspaces
San Diego Ca
Posted: 12/14/19 10:51am Link  |  Quote  |  Print  |  Notify Moderator
There's a vent pipe from the tank up to the roof. My trailer also has the gap at the top and bottom of the door. But the factory supplied fan is so powerful that it creates a low pressure situation in the trailer. In fact you can easily hear the fan speed up if someone opens the main trailer door while the fan is running. If you flush with the trailer closed up like first thing in the morning while everybody is asleep;The fan will pull air down the vent pipe and across the puddle of sewage in the tank and up through the toilet around your legs. Believe me it's not a mistake you're likely to make twice.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
opnspaces
San Diego Ca
Posted: 12/14/19 10:56am Link  |  Quote  |  Print  |  Notify Moderator
Yes check or replace your air admittance valves.
Link to valve
The valve breaks vacuum when the sink is shut off so the tank doesn't siphon out the trap. Look under the sink and there should be a vertical spur sticking up off the drain pipe. Unscrew it and see if the flapper works in one direction only. (air flowing into tank only) If it's bad you can get a new one for a few dollars at Home Depot. Just unscrew the old one and replace
CavemanCharlie
Storden,MN
Posted: 12/16/19 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
OK, I think what is going on here is that you have a RV toilet that has a water trap. Like a house toilet does. A lot of RV toilets have no trap and when you flush them you are just sliding open a door on the bottom of the toilet that lets the waste fall directly into the holding tank. If you have that type of toilet and you are running the exhaust fan while flushing it will draw air out of the holding tank and cause a smell in the RV.
Ron3rd
Upland, CA USA
Posted: 12/17/19 07:58am Link  |  Quote  |  Print  |  Notify Moderator
ScottG wrote:
If you want one that will last and don't mind paying a few extra bucks for it, "Sioux Chief" or "Studor" are the brands of choice.
Anything else is junk in comparison.
X2 on Studor, they have a stainless steel valve and cost around $15 and are white in color. The cheap black ones costing around $7 have a rubber flapper valve. Replace them one time with Studor
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
WTP-GC
FL
Posted: 12/18/19 05:01am Link  |  Quote  |  Print  |  Notify Moderator
Let’s offer some correction to the language used here:
Running the vent fan while flushing the toilet MIGHT cause odors to be drawn into the camper.
The AAV can fail and MIGHT cause odors to be drawn in.
Too many factors at play to use the word “WILL” when describing these situations.
In my case...
During warmer weather, as the black tank fills and there’s relatively stagnant air (no wind outside), odors can become more prevalent when flushing the toilet. A proper functioning vent relies in some part on having a little bit of air circulation. Kinda like how a chimney may not properly exit the smoke if it’s not above the ridge line of the roof.
* This post was edited 12/18/19 07:46am by WTP-GC *
Duramax + Grand Design 5er + B & W Companion
SBGTF
