RV.Net Open Roads Forum: Class A Motorhomes: Side mirror replacement
 > Side mirror replacement
Racklefratz
Everywhere
Posted: 12/28/19 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
beaubeau wrote:
These are not Velvac
If not Velvac, can't help.
But I can, and WILL, reiterate the cautions for Velvacs and the damned foam Tiffin squirts up into the backside of the cap, obscuring all the mirror wiring.
I broke the lower mirror housing on one of our Velvac mirrors, necessitating replacing it, and encountered the foam encasement issues with the wiring inside the cap. Gave up on it, due to concerns about butchering the wiring and not being able to reconstruct things, and decided to leave the mirror mount outside the cap as is, and splice wiring from there. The foam inside the front cap is a big problem if total mirror replacement is necessary.
2012 Tiffin Allegro Bus 43QGP
ArchHoagland
Clovis, CA, USA
Posted: 12/28/19 10:42pm Link  |  Quote  |  Print  |  Notify Moderator
beaubeau wrote:
These are not Velvac ... Rampro? Can't remember. But ... the trick was to put that retaining both back in, just a bit, and hammer upward on it [emoticon]
So you got it done OK?
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
wolfe10
Posted: 12/29/19 07:49am Link  |  Quote  |  Print  |  Notify Moderator
Likely RAMCO: https://www.ramco-eng.com/
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
wolfe10
Posted: 12/29/19 08:03am Link  |  Quote  |  Print  |  Notify Moderator
And, some technical support: https://www.ramco-eng.com/mirror-documents
