RV.Net Open Roads Forum: Class A Motorhomes: Side mirror replacement
 > Side mirror replacement
beaubeau
Posted: 12/12/19 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
A few weeks ago we had to get towed. The shop we were towed to reports the side mirror was broken. Without getting into how that happened .... has anyone replaced the side mirror on a 2008 Tiffin Allegro QDB? I’ve ordered the mirror and hope to take it with me when I go pick up the RV , hoping to replace it before I have to drive it.
Chip & Nancy (and our 3 Shelties and 3 Cavaliers). 2008 Allegro Open Road Freightliner.
johnsonbert
Houston, TX-Ironwood, MI
Posted: 12/12/19 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
I have replaced the mirrors on our Dynasty, and there is really not alot to it, as long as you have the direct replacement with the proper electric connection for adjustments and heat if installed. It involves 2-4 screws or bolts holding it to the body and an electric connection under the front cap. Depending on the mirror, it can be heavy and awkward and could be a 3-4 handed operation. Depending on the condition of your damaged one, I would save it for parts or reconditioning to sell, depends on the damage. I would have some sealant on hand to put back in the screw holes during assembly. Hope this may help. Happy Trails Bert
2006 Monaco Dynasty Diamond IV 42' Tag, ISL 400,(new to us), Residential Refrig, 10KW Onan, Bosch Washer/220V Dryer (previously 2003 American Tradition 40W) 2010 Chev Malibu LT
Wherever I happen to park
Posted: 12/13/19 05:08am Link  |  Quote  |  Print  |  Notify Moderator
If it is a Velvac Mirror replacent is easy.
remove broken glass at either the top or bottom you will see a piece of plastic that is a kind of latch. Carefully (And I mean Carefully) move the "Fingers" of the latch in to unlatch and push it down a bit.. Now hook the wires to the new mirror's heater (does not matter which one goes to which terminal electrically but may physically) and position the mirror. push the latch piece back into place and verify it latched.. Done.
Home is where I park it.
beaubeau
Posted: 12/13/19 06:48am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies! Very encouraging.
dougrainer
Carrolton, Texas
Posted: 12/13/19 11:43am Link  |  Quote  |  Print  |  Notify Moderator
Sorry, bad news if you are replacing the Arm and the mirror head. Tiffin foams in the 4 mount bolt nuts and washers and you will have to chip out that foam to get access in the front inside cap. Also, be VERY careful when chipping out the foam as the Camera and mirror motor wires are encased in that foam. If you can replace just the head and you are careful, you can splice the wires except for the camera wires. Usually, the camera has a quick connect inside the Mirror head. Doug
PS, YES, I have replace dozens of Tiffin mirrors over the years
pigman1
Delaware
Posted: 12/13/19 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
An added point... When Tiffin installs their mirrors, they hook up the mirror head to the wire harness in the arm, pull the harness tight from under the front cap and THEN FOAM OVER THOSE WIRES AND 4 ARM BOLTS. You'll probably have to at least dig the wires loose from the foam. Tiffin is definitely not overly generous with this part of the wire harness.
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
SMI Air Force One toad brake
Street Atlas USA Plus
beaubeau
Posted: 12/27/19 08:45am Link  |  Quote  |  Print  |  Notify Moderator
Thanks again for all the help so far... I have the new mirror and have the retaining bolt removed from the old one. Any thoughts on the the trick move to get the old one to release?
dougrainer
Carrolton, Texas
Posted: 12/27/19 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
So, you elected to do just the mirror head? To release it, make sure the Allen side screws are loose. If no Allen screws then just "pop" it with a rubber type mallet. Doug
Posted: 12/27/19 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
IF you are trying to remove the mirror arm from teh base.. In addition to teh set screws (hex wrench type) there is another bolt under the beast.. Major pain in the .... pain it's capped you can see the cap if you look UP. again this is for Velvac mirrors
Suggestion download the manual
beaubeau
Posted: 12/27/19 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
These are not Velvac ... Rampro? Can't remember. But ... the trick was to put that retaining both back in, just a bit, and hammer upward on it [emoticon]
