RV.Net Open Roads Forum: Tech Issues: WFCO converter for lithium batteries
 > WFCO converter for lithium batteries
noteven
Turtle Island
Posted: 12/13/19 11:07am Link  |  Quote  |  Print  |  Notify Moderator
My camper has a 55amp WFCO power center. I see a module on their website to change it over for using with LiFe04 batteries. I expect the battery monitoring system in the “lead acid replacement” type lithium batteries will protect them from the charging sources (WFCO / Zamp solar) going crazy and wrecking them.
Has anyone got any experience using the WFCO lithium module?
bpounds
Sophmore Brain...
Posted: 12/13/19 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
Someone might happen along who has done that. But I wouldn't hold my breath. I wouldn't spend a dime to save a WFCO converter. I would replace it with a better unit.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
noteven
Turtle Island
Posted: 12/13/19 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
Actually a knowledgeable friend of mine who has built their own rig that is all electric and solar/lithium powered says based on my rig’s electricity needs a conversion to lithium is a waste of money.
BarabooBob
Baraboo, WI
Posted: 12/13/19 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
I have a brand new WRCO converter in my garage that I will giver anyone that wants to pay the postage. I installed a Progressive Dynamics unit and my installed DC volt meter shows the converter working properly by switching between the different charge rates. The WFCO just sat at 13.2 volts even when the batteries were run down. The TT was 3 months old when I did the upgrade.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
noteven
Turtle Island
Posted: 12/13/19 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
Bob it sounds like you have a faulty WFCO that should have had a warranty claim made - mine 3 stage charges the wet batteries.
I have 2 other rigs with PD power centres that are good units. They are 90 amp (I think) anyway they will make a Honda 2000 throttle up when they bulk charge flat batteries
ORbiker
Springfield, Oregon
Posted: 12/13/19 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
Get rid of the 55amp WFCO power center. POS
LinkConversion table.
I (2-10-05) bought a 2002 F350 CC SWD PSD and a new 2003 Citation 10'8. I have been a tent camper all my life. I wanted more comfort while camping and CraterLake Ski Patrol.
It's time for more space. I purchased a 2016 Grand Design 380TH as of 10-29-2015.
time2roll
Posted: 12/13/19 10:15pm Link  |  Quote  |  Print  |  Notify Moderator
WFCO lithium MBA manual
So basically it just skips the float mode of 13.2 volts.
I see no description on how long the 14.6 volts is held.
675w Solar pictures back up
Wherever I happen to park
Posted: 12/14/19 04:01am Link  |  Quote  |  Print  |  Notify Moderator
WFCO is not the best choice in converters for starters.
From what I have been led to believe Progressive Dynamics now has a Lithium version of at least one converter.. BUT it may be brand of battery specific.
Also "lithium" is half a battery.. the other half determines the specific charger needs. Li__ or Li___ and how you fill in the blank matters.
Home is where I park it.
drsteve
Michigan
Posted: 12/14/19 07:36am Link  |  Quote  |  Print  |  Notify Moderator
Are newer WFCOs still junk? The one in my 2018 Coachmen seems to do fine. I leave it plugged in all summer and not only does it keep it charged, it has yet to boil the battery.
1991 Palomino Filly PUP
BFL13
Victoria, BC
Posted: 12/14/19 08:27am Link  |  Quote  |  Print  |  Notify Moderator
The "junk" rep is partly due to an anecdotal higher failure rate of its components compared with other brands. I have no statistics on that to confirm if true.
The other big reason is the design. The 13.2v trigger to go into boost mode is unsuitable for RV use, where that 13.2v trigger would seldom occur.
There have also been complaints on here that some do not drop to the 13.2v storage mode after being at 13.6v. No info on whether this is a component failure example or if it is to do with the design/RV installation in those cases.
On balance, if you have a choice, why risk it?
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
