RV.Net Open Roads Forum: Tech Issues: WFCO converter for lithium batteries
 > WFCO converter for lithium batteries
azrving
Oatman
Posted: 12/14/19 09:01am Link  |  Quote  |  Print  |  Notify Moderator
A WFCO? That's like using a boat anchor to fix a fine watch. Oh wait, I forgot, they aren't heavy enough to be a boat anchor. Trash that thing.
ORbiker
Springfield, Oregon
Posted: 12/14/19 09:21am Link  |  Quote  |  Print  |  Notify Moderator
Read about 4 stage chargers. That will give you some clues.
Our batteries are much happier with the Progressive Dynamics. I don't have Lithium batteries yet. The Lithium's want 14 or so volt pounded into the batteries till full. KEN
I (2-10-05) bought a 2002 F350 CC SWD PSD and a new 2003 Citation 10'8. I have been a tent camper all my life. I wanted more comfort while camping and CraterLake Ski Patrol.
It's time for more space. I purchased a 2016 Grand Design 380TH as of 10-29-2015.
BarabooBob
Baraboo, WI
Posted: 12/14/19 09:24am Link  |  Quote  |  Print  |  Notify Moderator
The reason I did not do a warranty claim on the WFCO was that they would just give me another WFCO. I had 2 of them over the years and neither one would go into the bulk charging mode even if the batteries were low. If I am going to take the time to replace a converter, I only want to do it once, so, I bought and installed my own Progressive Dynamics unit. The PD unit works perfectly. I have a built in digital volt meter that shows the system going through the step down process.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
BFL13
Victoria, BC
Posted: 12/14/19 09:54am Link  |  Quote  |  Print  |  Notify Moderator
AGMs require 14.x volts( where x depends on the specs of that AGM--some at 14.4ish some at 14.8ish) to be held all the way till they are full, indicated by amps tapered down to 0.5a/100AH of battery bank.
Flooded batteries also benefit from that charging profile.
That is not being "pounded". Batteries have a "natural acceptance rate" for amps absorption, which you see during the Absorption Stage as amps taper.
Stepping down to a lower "absorption voltage" before the battery is fully charged can lead to undercharging and sulphation.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
time2roll
Posted: 12/14/19 10:03am Link  |  Quote  |  Print  |  Notify Moderator
drsteve wrote:
Are newer WFCOs still junk? The one in my 2018 Coachmen seems to do fine. I leave it plugged in all summer and not only does it keep it charged, it has yet to boil the battery.
Do you actually measure 14.4 volts charging when expected?
Would love to see some positive reports on WFCO.
675w Solar pictures back up
noteven
Turtle Island
Posted: 12/14/19 10:46am Link  |  Quote  |  Print  |  Notify Moderator
ORbiker wrote:
noteven wrote:
My camper has a 55amp WFCO power center. I see a module on their website to change it over for using with LiFe04 batteries. I expect the battery monitoring system in the “lead acid replacement” type lithium batteries will protect them from the charging sources (WFCO / Zamp solar) going crazy and wrecking them.
Has anyone got any experience using the WFCO lithium module?
Get rid of the 55amp WFCO power center. POS
LinkConversion table.
Thanks ORbiker - the linked table is the info I need. I’ve been happy with the PD unitsin my other rigs. I may change the whole unit out and add some more solar and stay with flooded or agm so as not to have to deal with protecting lithium batteries from cold.
Edit - looking at the PD4655 models at Best Converter PD has the 4655LV model which can be changed from flooded/agm mode to lithium charging- this would be ideal.
* This post was edited 12/14/19 11:15am by noteven *
BFL13
Victoria, BC
Posted: 12/14/19 11:18am Link  |  Quote  |  Print  |  Notify Moderator
That link is just an ad for PDs. There are other choices that will also work with various Li batteries.
It also looks like many ads are jumping on the Li bandwagon by suggesting Li is more different than it is, so you just have to buy their latest thing now that it says Li somewhere on it.
Actually, from threads on here it looks more like the difficulty is trying to figure out Li SOC between what their balancing gizmo says and what your battery monitor says. The good thing there is that it seems the Lis do ok not being fully charged, so their actual SOC doesn't matter so much.
Too complicated for me! (Also way too expensive)
time2roll
Posted: 12/14/19 11:33am Link  |  Quote  |  Print  |  Notify Moderator
Power center is fine. It is just the converter MBA that often fails to work as designed.
noteven
Turtle Island
Posted: 12/14/19 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
It’s actually a link to PD’s website, not an ad. I’ve had excellent service & performance from 2 other PD charge converters so I am ok with one more. My base camp trailer sits plugged in to shore power for weeks at a time. Batteries need watering once per year on PD “Charge Wizard” equipped charger. They hurry up and bring the batts to 80-90% if a generator run is needed not on shore power. If I buy LiFe04 I will be looking for long warranty which might indicate a good BMS is installed ... but I’m sure someone will be along to contradict that...
bpounds
Sophmore Brain...
Posted: 12/14/19 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
More solar may be your best choice. Optimize your charge controller to compliment whatever batteries you choose.
I've left my WFCO converter in place, after years of planning to replace it with a PD. I went solar instead. The converter sits there switched off, and only gets turned on if a couple cloudy days come along and the genny comes out. Rare event, so no sense replacing the converter, but if it ever dies I certainly would not buy another WFCO.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
