RV.Net Open Roads Forum: How much water to ad to black tank when starting out.?
 > How much water to ad to black tank when starting out.?
Spade Cooley
Mountain View, AR
Posted: 12/13/19 11:31am Link  |  Quote  |  Print  |  Notify Moderator
I'm not a beginner and have never had trouble with blockage but know a number of people who have, My neighbor in this RV park is currently stopped up and had to buy a solution to dump into her tank to free it. I normally ad between 3 and 4 gallons of water and two containers of treatment to start out and have never had a problem. What is the minimum you should start out with in the black tank. Is it different while driving on a trip than when you are stationary in a park? Opinions will be respected.
Second Chance
Wherever...
Posted: 12/13/19 11:37am Link  |  Quote  |  Print  |  Notify Moderator
Like you, I put about 4 gallons of fresh water in the black tank after emptying - but I've never used any additives. I've also not had any issues in over four years of full-timing. Several times a year I will use the "Geo method" to clean the tanks: about 1/3 tank of clean water with some dish detergent and borax crystals before hitting the road. The agitation and solution help clean off the level sensors and get residual "stuff" off the sides of the tank(s).
Rob
U.S. Army retired
2016 Grand Design Reflection 337RLS
MOR/ryde independent suspension, disc brakes, LR G tires
2020 Solitude 310GK-R on order (with MORryde IS)
PullRite OE 18K, Demco Glide Ride pin box
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
midnightsadie
ohio
Posted: 12/13/19 11:43am Link  |  Quote  |  Print  |  Notify Moderator
I have a smaller rv only 24ft I put about a gal of water in the tank ,just its not sitting dry no chemicals. we empty the tank after each trip and hose out . I think thats the answer to not having a clogged tank.
schlep1967
Harrisburg, PA
My opinion. It really depends on your black tank. You need enough water in it that solid waste can be mostly or completely submerged so it can soften up and or break down.
And yes it is different if you are sitting in a park vs moving around "stirring" the contents of the tank. The treatment chemicals are more important when sitting still.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
shum02
Burlington ON CDA
Posted: 12/13/19 11:50am Link  |  Quote  |  Print  |  Notify Moderator
I usually say about 10% of the capacity of the tank. Has worked great for me, never had a problem. Dish or laundry detergent are the only two chem's that I add to my tanks, again, not a problem.
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
wildtoad
Blythewood, SC
Posted: 12/13/19 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
I never add water to the black tank when starting a trip cause I always keep some water in it which I think is the best thing to do to prevent “stuff” from sticking to the bottom, sides, valves. After I dump and flush, I simply put one or two toilet bowls worth of water in the tank.
Tom Wilds
Blythewood, SC
Lynnmor
Red Lion
Posted: 12/13/19 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
The pipe from the tank to the dump valve needs to be filled plus a few gallons more. Some dump valves are right on the tank and some are quite distant, so the answer will not be a certain number of gallons. If you can see the tank bottom, measure the number of gallons or bowl fulls it takes to cover the bottom of a completely empty tank. When using an additive to control the odor, don't add it till the water fills the aforementioned piping so it is in the tank.
cavie
Posted: 12/13/19 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
two full bowls of water should do the trick. Never leave it dry.
Ed_Gee
Central Oregon coast - Winter in AZ
Posted: 12/13/19 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
I usually use the tank sprayer after dumping so after a few minutes of rinsing, I close the black tank valve but leave the sprayer going long enough add at least a gallon or two.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
bikendan
Camano Island, Wash.
Posted: 12/13/19 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
3-5 gallons.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
