RV.Net Open Roads Forum: How much water to ad to black tank when starting out.?
 > How much water to ad to black tank when starting out.?
edatlanta
Jennings Ferry Campground-Camp Host, Akron, AL
Posted: 12/17/19 04:46am Link  |  Quote  |  Print  |  Notify Moderator
Oasisbob wrote:
In my 17 years with this trailer I have never even considered adding water. My bathroom sink does empty into black however. I do use an internal on board sprinkler type sprayer when I dump where available. Maybe that helps?
I am now 9 years+ full time and I NEVER add water after a dump. I do boondock a couple of weeks a year and really want full black tank capacity when I start. If you are going to be using it why start out with extra water in the tank?
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
bigred1cav
ohio
Posted: 12/17/19 10:20am Link  |  Quote  |  Print  |  Notify Moderator
5 gallon and a 10 pound bag of ice
ReneeG
Meridian, Idaho
Posted: 12/17/19 10:29am Link  |  Quote  |  Print  |  Notify Moderator
NRALIFR wrote:
You might also check to make sure she isn’t leaving the black tank valve open all the time. That will cause problems for sure.
[emoticon][emoticon]
Bingo! When hooked up at a park, leave your tank valve closed and don't open it till you dump it prior to leaving. Leaving the valve open allows liquids to flow through and the solids to sit. You need all the liquids in it to move the solids.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
doxiemom11
Yoakum Texas
Posted: 12/17/19 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
Couple of full bowls, and generous water when flushing, never any additives. We are full-time though, so it is always being used.
Edd505
Elephant Butte, NM
Posted: 12/17/19 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
black tank flush after dumping & closing the black valve 3-4 minutes, yes minutes. I drive to the next RV Park and dump as needed. When leaving, dump flush and add as stated. Repeat, not a chance it will clog and the clean water driving helps breakup & clean for the next stop. I have a 57 gallon black and it takes weeks to fill with the added water.
(1 minute = 3-5 gallons depending on flow rate)
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
rvshrinker
Beautiful Pacific Northwest
Posted: 12/19/19 08:12am Link  |  Quote  |  Print  |  Notify Moderator
I just hold the toilet plunge open for a minute or so. No problems.
ppine
Northern Nevada
Posted: 12/19/19 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Nada.
OleManOleCan
Alabama
Posted: 01/16/20 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
Second Chance wrote:
Like you, I put about 4 gallons of fresh water in the black tank after emptying - but I've never used any additives. I've also not had any issues in over four years of full-timing. Several times a year I will use the "Geo method" to clean the tanks: about 1/3 tank of clean water with some dish detergent and borax crystals before hitting the road. The agitation and solution help clean off the level sensors and get residual "stuff" off the sides of the tank(s).
Rob
I adopted the Geo Method a number of years ago. After I dump the Black tank, I like to put in a 1/2 bottle of Calgon and a good bit of dish soap. I top it off with 3-4 gallons of water. The ride to my home cleanses the tank. I do he same with my Grey Tank. BTW: It never hurts to put some in your sink traps. No odors...
jdc1
Riverside, Ca
Posted: 01/16/20 10:33pm Link  |  Quote  |  Print  |  Notify Moderator
bikendan wrote:
3-5 gallons.
Correct answer (and a couple others). Use granular laundry soap once in while too, before traveling (said prior). That stuuf they sell to breakdown solid waste is useless....It's just deoderizer.
univmd
Maryland
Posted: 01/22/20 08:02am Link  |  Quote  |  Print  |  Notify Moderator
We don’t pre-add water. We go to the bathroom a lot though so it never really dries out.
2008 Gulfstream Tourmaster
2011 Honda CRV
Blue Ox Baseplate & Socket Wiring
Blue Ox Alladin Tow Bar
US Gear Unified Tow Brake
