RV.Net Open Roads Forum: How much water to ad to black tank when starting out.?
 > How much water to ad to black tank when starting out.?
Spade Cooley
Mountain View, AR
Posted: 12/13/19 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
I put in about three gallons of water and then ad my solution. I am in this park for a month. My neighbor, a single woman, is the one that is plugged. I advised her that after the plug is over to ad 3 gallons of water. She has been doing this for a long time and should have figured it out.I need to check with her and find out if she is clear. I'm convinced she plugged her line due to lack of water.
Bobbo
Wherever I park
Posted: 12/13/19 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
I put two toilet bowls full. I figure each toilet bowl full is approximately a gallon.
I also put two toilet bowls full every time I flush "solids."
Bobbo and Lin
Veebyes
Posted: 12/13/19 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
It depends. I have no idea of exactly how much. It depends on time & CG water pressure. The built in sprayer gets hooked up & turned on first before the hose goes into the dump & does not get turned off till after the big gush of the grey.
Must be a gallon or so put in to slosh around & hopefully prevent the dreaded cone. At least 1800 nights of use & have only had one blockage. Bought the wand thinghy. Worked well.
2007 Alpenlite 34RLR
Oasisbob
Portland Oregon 97266
Posted: 12/13/19 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
In my 17 years with this trailer I have never even considered adding water. My bathroom sink does empty into black however. I do use an internal on board sprinkler type sprayer when I dump where available. Maybe that helps?
Oasis Bob
Wonderful wife & 4 Really Fun kids
2008 KIA Sedona 3.8L 24 valve V-6
2001 Bantam Trail Lite B-19
HAPPY TRAILS">
NRALIFR
Truck Camping Out West
Posted: 12/14/19 04:03am Link  |  Quote  |  Print  |  Notify Moderator
You might also check to make sure she isn’t leaving the black tank valve open all the time. That will cause problems for sure.
[emoticon][emoticon]
2001 Lance 1121 on a 2016 F450
tomman58
Southeast Michigan
Posted: 12/14/19 08:29am Link  |  Quote  |  Print  |  Notify Moderator
I,ll add one more thing my wife doesn't flush the TP after she takes a wizz she puts it into the waste basket near the toilet. The amount of TP is drastically reduced. She got this idea after Brazil they don't flush any paper there because of bad plumbing there.
2015 GMC D/A, CC 4x4/ Z71 ,3.73,IBC SLT+
2018 Jayco 338RETS
2 Trek bikes
Honda EU2000i
It must be time to go, the suns out and I've got a full tank of diesel!
We have a granite fireplace hearth! Love to be a little different.
opnspaces
San Diego Ca
Posted: 12/14/19 09:28am Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
OP, presume you're in the park with the neighbor? Whatever you're doing must be working, so what doo you doo?
People fail to realize that campers on the move don't hardly ever have issues because they are on the move.
But if you're parked, it's like a portapotty. Even though there's liquid, mount poosoovius is still a real concern.
Use some common sense and don't just ASSume that once hanky the christmas poo disappears down the drain, he's magically gone!
Gritdog, well worded, that got a laugh out of me. [emoticon]
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
opnspaces
San Diego Ca
Posted: 12/14/19 09:50am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
opnspaces wrote:
After dumping I let the tank sprayer run for 30 seconds to maybe a minute. I would guess that equates to about a gallon of water.
Please don't guess. Next time simply measure the liquid.
I don't add water before trips. I don't use chemicals. I have had zero problems with the waste tanks.
Nah, I just don't put that much thought into dumping the tank to worry about it. The only reason I leave any water in it at all is...you know I'm not sure why I leave any water at all. I guess it's something I picked up here many years ago. I agree with not adding chemicals, never have and I don't notice a smell.
shum02
Burlington ON CDA
Posted: 12/15/19 07:19am Link  |  Quote  |  Print  |  Notify Moderator
Lwiddis wrote:
I put two gallons in my 25 gallon black tank after dumping but most of the first couple of gallons dishwater gets poured into it too.
We use plastic totes in the kitchen sinks for washing and do the exact same thing. Nice warm soapy dishwater, works like a charm!
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
bguy
The Rock
Posted: 12/16/19 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
Fill the toilet to the top twice. About 3 or so gallons.
2011 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
