RV.Net Open Roads Forum: Tech Issues: Solar panels
 > Solar panels
Johnny G1
Clearwater, British Columbia ,Canada
Posted: 12/14/19 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
8 T105's and 600 watts of Kyocera panel's, use batteries for everything in the coach and the same for the fw which 2 batteries and 120 watt of solar.Also carry a Honda 3000i for the air.
98 Mountain Aire 34' 210 Cummins Puller and 2001 dodge dully with all the toy's, 400 + hp pullin a 28' 5th wheel Travel Aire. Lots of fun.
Boon Docker
Posted: 12/14/19 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
theoldwizard1 wrote:
Trackrig wrote:
It depends on so many variables:
Solar is like horsepower, you never have too much and solar is cheaper than horsepower.
I'll have to remember that last line !
Boon Docker wrote:
I have 200 watts of solar with an MPPT controller feeding a 225 AH battery bank (two GC-2 6v batteries).
I boondock for weeks at a time and the batteries are fully charged by early afternoon as long as it is not cloudy.
I would consider this setup and absolute MINIMUM !
Yeah, a person needs at least 600-800 watts of solar and at least a 500 AH battery bank to boondock for a few days. [emoticon]
Johnny G1
Posted: 12/14/19 10:25pm Link  |  Quote  |  Print  |  Notify Moderator
When you boon dock all winter in Arizona you need lots of solar if you want to live like you do at home, Just my thought's.
pianotuna
Regina, SK, Canada
Posted: 12/14/19 11:51pm Link  |  Quote  |  Print  |  Notify Moderator
This may help:
https://freecampsites.net/adding-solar/
Regards, Don
PNW_Steve
Pacific Northwet & cold
Posted: 12/15/19 03:55am Link  |  Quote  |  Print  |  Notify Moderator
Lwiddis wrote:
Do an energy use survey...actual or what you’d like to use. Your choice. That determines the battery amp hours needed, which determines the solar watts you need to recharge and the controller size. If you guess, you will be either undercharged or overpaying.
“battery charged for a few days of boondocking” is absolutely wrong. A properly sized solar system recharges fully almost every day. Limping along...for a few days? Solar isn’t a new toy or experimental.
Good advice.
I have a Kill-A-Watt meter that has been invaluable for getting real world power consumption of my 120v loads. I also have a Trimetric TM-2030 for measuring consumption of my 12 volt and 24 volt loads. The Trimetric will be my onboard battery monitor.
2004.5 Dodge 3500 5.9 Cummins, NV5400, 5" turbo back stainless exhaust, Edger programmer & 22.5 Alcoa's
2002 Forest River 36 5th Wheel (staying home)
1992 Jayco 29 5th Wheel (Mexico veteran & headed back)
2002 "faux" Wanderlodge 40' My new toy....
jplante4
Cape Cod
Posted: 12/15/19 06:49am Link  |  Quote  |  Print  |  Notify Moderator
I'm running 4 GC2s with 200 watts of solar on the roof and another 130 watts in a portable panel. I can go until the tanks fill up (about 5 days, but we're not anal about water usage). I do need to run the generator for a hair dryer [emoticon], so I top off the batteries then.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
tbax46
Wichita Falls
Posted: 12/15/19 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
I thank everyone for the info. I probably will just be using 12v for 2-3 days for the lighting and igniters. Got some Forest Service campgrounds that are nice for a couple of days.
Reflection 337
Silverado 3509HD
USN & 'Nam Vet
Boon Docker
Posted: 12/15/19 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
Something like this 200 watt portable would work good for you if you don't want a permanent setup.
 > Solar panels
